#161
Re: New Mac Pro (7.1)
Luke, will you post some photos of your tails and rack extenders installed. Grab different angles and such. I have a similar issues with racking the Dolby Atmos RMU, and I bought several styles of extenders. I eventually found one that worked best. I might be able to brainstorm a different configuration for you. BTW, can you also post the specs of which 7,1 configuration you got? I looked back earlier in the thread and couldn’t find it.
Pro Tools Ultimate, HDX3 & MTRX + HD MADI 7,1 MacPro, 3.2GHz 16-core, OSX 10.15 S6 M40 48-5, panners, MPM,Dolby Atmos RMU AJA Kona LHi, Sync HD www.ToolshedAudioPost.com www.TheToolshedStudio.com Certified for Dolby Atmos Home Entertainment |
#162
Hi Lucien,
I am thinking about upgrading to the W5700X mostly for the extra Thunderbolt buses (it adds two). Apropos of my earlier point about CPU usage, it could simply be that the Pro Tools CPU usage meter includes PCIe bus bandwidth, and that explains the three-fold difference. The session I tested had a lot of high latency plugins in it (e.g. iZotope) so play start felt laggy, but that's not really the computer's fault. So more investigation is required. However, I will say that some general things such as, say, Installer did not feel any faster than my MacPro5,1 – I kind of hoped it would have a bit more “new computer snap” to it.
https://lukehoward.com/ |
#163
There are some tutorials on the web somewhere about swapping out the removable drive icon for a standard internal drive icon.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command. |
#164
#165
Is it really applicable beyond aesthetics though? From my understanding, the disk arbitration script applies to any disk beyond the root drive. All it is really doing in the case of the 4M2 is identifying that it is running on I/O outside of what comes internally native to the system. From my experience, most PCIe based solutions are identified in a similar way by OSX. OWC are a reputable brand. If altering the way the 4M2 was identified by OSX improved its performance rather than its aesthetics, they probably would have addressed it.
#166
#167
I don't disagree with you... but it is Apple. The 5,1 was 8 years ago. A lot has changed. Why put proprietary connectors on hard drives? Why install T2 chips? Why solder components to motherboards? Why glue batteries in laptops?
#168
True, hard to disagree. I guess I should file a bug...
#169
What is the point your are trying to make?
#170
That user-upgradability and Apple still remains largely an oxymoron.
