Old 11-20-2017, 04:37 AM
Southsidemusic's Avatar
Default Re: More issues with AIR...this time Transfuser
Yep. Last night I tried and it doesn't happen Donald. I am sorry but can't get those presets to load here either ... not surprised really, just meh!
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 11-20-2017, 05:07 AM
Originally Posted by Southsidemusic View Post
The only little niggle is the JL Cooper striping box that take up ch24 and sometimes bleed over to ch 23 even though ch24 is the sync track :/
I've heard of quite a few engineers that just skip track 23 for anything because of this. Then again I wish I had problems like this
Jack
QAPLA!
Old 11-20-2017, 07:24 AM
DonaldM's Avatar
DonaldM DonaldM is offline
So there's two of you with the same issue. and I believe you're running on a Mac system, no? I'll add to my reporting on this to AIR.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
DonaldM's Avatar
Originally Posted by remute View Post
Confirmed here, the Gater presets don't load anything/are all the same.
Did AIR "support" ever get back to you?
thank you for checking. May I ask are on a Mac or PC? (AIR will ask)
Old 11-20-2017, 07:55 AM
remute remute is offline
Mac - El Capitan, PT 12.2.
Good luck getting a fix from AIR.
  #16
Old 11-20-2017, 08:14 AM
DonaldM's Avatar
Thanks!
  #17
Old 11-20-2017, 11:11 AM
I tried on one of our trashcans osx Sierra 10.12.6 and my brand new MBP with high Sierra and one MBP 2014 with Sierra 10.12.6 and all three has the same issue. HD 12.8.1 and HD 12.8.2 so not a 12.8.2 problem solely.
Best Regards
Christopher
#thestruggleisreal
WEBHOME
  #18
Old 11-20-2017, 12:43 PM
DonaldM's Avatar
Thanks for the info Christopher. I'm passing this on to AIR and see what they say. Its either a glitch with Transfuser not reading the pull down menu OR they simply overlooked including the patterns with the IEP package.
  #19
Old 11-20-2017, 12:51 PM
DonaldM's Avatar
By the way, in spite of the glitch, this can be a really cool effect. Try this sometime. Take a VI of your choice with a more sustained patch of some sort. Then, insert Tranfuser on the same intrument track, right under the VI. In Transfuser use the "Def Audio In" option from the menu. This installs a blank audio input module in the Transfuser rack. Now, insert Gater on the module insert. Then, use the Gater creator in the bottom window in Transfuser to create your own effect. Change the rate, or whatever.
I'd start with the AMP lane and create a pattern. Then play with the other parameters on any beats where the AMP is on. Especially play with pan, gate and cutoff. When you get something you like, try adding another effect, ie Phaser or delay or both. It can funky fast! You can get some really nice gated effects this way on any patch off any VI.
  #20
Old 11-20-2017, 01:39 PM
Thanks Donald
Will definitely try that out. In all honesty I have not used Transfuser once on any songs we completed for artists, I know that a few of our in house producer interns have used it but I have not. I need to really start using the stuff we paid a lot for here hehe
Best Regards
Christopher
#thestruggleisreal
WEBHOME
TRANSFUSER dragging into pro tools in half-time babygoboom Virtual Instruments 1 09-15-2017 08:23 AM
Transfuser: My list of issues Gothboy Virtual Instruments 0 10-03-2010 08:11 AM
transfuser recording issues kalony Virtual Instruments 0 07-27-2009 10:04 AM
Transfuser Sync Issues remute Virtual Instruments 14 01-13-2009 02:37 AM
Transfuser Install Issues djad05 Virtual Instruments 4 01-09-2009 03:29 PM
