Old 09-15-2013, 11:02 AM
trakslasha trakslasha is offline
Default Elastic Audio Error when launching PT 11.0.2
I installed 11.0.2 but I get an elastic audio error when launching...anyone else experiencing this?
Old 09-17-2013, 09:30 AM
robinfile robinfile is offline
Default Re: Elastic Audio Error when launching PT 11.0.2
yep i've got the same..probs with the dll....going back to 11.0.1
Old 09-17-2013, 12:12 PM
Go into the system plug ins folder in version 11.0.1,Go to the Elastic Audio plugin folder, copy it and paste it in the same location in 11.0.2...worked for me.
Old 09-17-2013, 03:32 PM
iAmMartian iAmMartian is offline
really i would try it. but i already re-install the 11.0.1. so i cant bother again
Old 09-18-2013, 05:09 AM
(windows 7 sp1) ..as posted before had elastic audio plugin error when booting 11.0.2. after clean install....tried clean install of 11.0.1. and then installing 11.0.2. as an update...11.0.2. booted up without the plugin error but was very slow and crashing...copied the elastic audio plugin from the system plugins folder to the desktop and uninstalled protools ,also manually removed all avid/digi folders from the program files folder ..left the air creative collection intact... i then did a clean install of 11.0.2, restarted,and pasted the elastic audio plugin folder(from desktop) back into the ptools system plugins folder (copying and replacing)...ptools 11.0.2. started up perfectly with no issues so far...will try using the elastic audio now to make sure.....
worth a try 30 mins max
Old 09-22-2013, 11:24 AM
Lpmike75 Lpmike75 is offline
This worked for me too! Thanks!
Old 09-27-2013, 05:46 PM
therealms therealms is offline
I'm having the same problem but 11.0.2. is my first pro tools so i can't go back to a previous version of 11. I could download 10 but I'd rather have 11 working perfectly, is there a different solution to this problem?
Old 10-02-2013, 07:37 PM
thatt guyyyy thatt guyyyy is offline
Default Elastic Audio can't be loaded when launching PT11
when i start pro tools 11 elastic aax message pops up saying it couldnt b loaded what should or oculd i do ?
Old 10-02-2013, 07:45 PM
DPeifer DPeifer is offline
This may be due to files getting left over on an uninstall and upgrade to Pro Tools 11.0.2. I would recommend the following in an attempt to resolve this:
1. Uninstall Pro Tools from the Control Panel.
2. Manually uninstall whatever is left behind from:
• Program Files/Avid/Pro Tools
• Program Files/Common Files/Avid
3. Re-install Pro Tools 11.0.2.
If this still doesn't work, it might be good to trash the Pro Tools and DAE Preferences. If that still doesn't work, I would reply to this thread. Providing Avid ".dlog" files may assist in resolving this problem.
Hope this helps.
-david
Old 10-03-2013, 08:07 PM
I did all the stuff David recommends, multiple times. The only thing that worked was the previous post on saving the Elastic Audio folder from 11.01 install, then install 11.02 and replace that Elastic Audio folder with your saved version from 11.01.
Good luck
Elastic Audio Error Sid0 Windows 4 02-12-2014 05:11 PM
Elastic audio error message and more tomdiek macOS 1 07-25-2012 04:32 PM
Elastic Audio Error Kenny Gioia Pro Tools TDM Systems (Mac) 18 07-09-2010 06:19 AM
Elastic Audio Error PoP Up I've never seen before oulablank 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 10-10-2009 02:11 PM
error -9025 when launching Logic Audio Enis Presheva Jr. Pro Tools TDM Systems (Mac) 0 07-07-2001 12:36 AM
