Old 09-02-2011, 08:54 AM
xazqe xazqe is offline
Default Pro Tools 9.0.5 - Low Latency Monitoring problem still persists
I've just updated to LE 9.0.5 and I've found that there's still a problem with LLM.
In this scenario LLM does work:
http://uprightsounds.com/pics/other/LLM_working.png
Whereas here it doesn't:
http://uprightsounds.com/pics/other/LLM_not_working.png
Bottom line; LLM doesn't work on record enabled audio tracks if that track is going straight out to Output 1-2 while another track is routed to an AUX. LLM does work if all channels are routed to the same AUX or if there's no AUX present at all (just one single audio track in session). Without any plugins or sends loaded on any tracks.
This is very annoying when I'm doing retakes in projects through Eleven Rack and for guitarists Low Latency Monitoring being essential.
Tech support???
Low Latency Monitoring problem TheRetreat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-26-2012 10:05 PM
Low Latency Monitoring problem stickers76 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-04-2012 01:10 AM
Low Latency Monitoring BIG PROBLEM reedmountainman Digidesign Hardware & Software 0 02-28-2007 07:40 AM
low latency monitoring problem amystolz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-23-2005 09:10 AM
Low Latency Monitoring problem in 6.4 (bug?) p0rk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 11-06-2004 05:47 PM
