Old 06-12-2011, 12:09 PM
audio1420 audio1420 is offline
Default Protools 9.0.3 Wont Load..
Whats up all. We just got an HD2 accel system and theres an issue... When I goto load protools 9 it gets to Initializing hardware (DSI) and then locks up... When I run digitest and both cards are installed in the computer witch is a G5 2.66 dualcore intel xeon with 4 gigs of ram. Nothing happens digitest wont even open... As soon as I take out the accel card and restart protools no problem everything loads up just fine... I load digitest it opens I run digitest core card passes... Is there any other way to test the Accel card to see if I got a bad card... The order the cards are installed is slot 1 video slot 2 core, slot 3 accel...Thanks
Old 06-12-2011, 08:42 PM
Chief Technician's Avatar
Question Re: Protools 9.0.3 Wont Load..
Do you have the ribbon cable between the Core and Accel card connected properly? You have to connect it to port B on the Core card and port A on the Accel card.
Old 06-13-2011, 10:27 AM
Default Re: Protools 9.0.3 Wont Load..
Yes I do... Its just odd that that it works just fine with out the accel card... Anyway the accel card just got shipped back nextday and should have a new one in a couple of days...
Protools wont load Drakui Pro Tools M-Powered (Win) 2 04-04-2011 03:27 PM
protools wont load any of the vst !!PLEASE HELP!! millz85 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-01-2010 01:30 PM
Protools 8.0 cs1 wont load sessions digartisan Pro Tools TDM Systems (Mac) 3 01-26-2009 05:27 PM
PROTOOLS WONT LOAD? RoyaltyOnline 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-14-2007 10:29 PM
protools free on mac os9 wont load,,, cowbell fever Digidesign Hardware & Software 1 07-08-2003 11:18 PM
