Old 05-03-2005, 08:08 AM
Fladlien Fladlien is offline
Default External Hard drive problem
I got an USB 2.0 (unfortunetly at the time I didn't know that digidesign doesn't support it) and I am trying it out anyway in hopes that it will work. I went to workspace to switch it to become a Recording drive, but when doing so I am hit with this prompt:
"External DRIVE" cannot be designated as an audio record volume because it is not a valid audio volume"
Is there something I have to change in order for my external drive to become a valid audio volume. If not, is it still possible just to use it for back up purposes, but not to stream audio directly from? It's too late for me to return the darned thing, so I am trying to make the best out of a bad situation. Any help in this regard would be greatly appreciated.
Old 05-03-2005, 08:55 AM
Musick Musick is offline
Default Re: External Hard drive problem
Have you format it?
Old 05-03-2005, 09:30 AM
DigiTechSupt's Avatar
USB 2.0 drives are not qualified for use with Pro Tools and can only be used as transfer volumes.
Avid Audio Tech Support
Support FAQ
Old 05-03-2005, 10:21 AM
Icabod Icabod is offline
USB 2.0 drives can be used as recording drives. I do it every day.
They may not be qualified, but in my case, a FireWire drive would not work properly.
My drive enclosure has USB 2.0 and FW, so since I had an impending job and no time to replace the drive...
My only option was USB 2.0. It has been working flawlessly for almost a year now.
It may not be qualified, and it may not be supported, but when I lost an entire show by going the "supported" route, no one from Digi helped me, and my data was unrecoverable.
I'd say experiment before you do anything important. I don't have my machine in front of me right now, but I didn't have any problems setting up the drive for recording. I have been running OS 10.3.4, and PTLE 6.4 the whole time.
12" PB 1Ghz, 512 RAM, Panther
002R PTLE 7.1
60 Gig Maxtor 7200, Oxford 911 FW/USB2 box
Old 05-03-2005, 10:34 AM
lonestarparis lonestarparis is offline
DigiTechSupt
What type of HD, supported by Digi, would you advise in this specific case?
PT 10.3.7
iMac late 2014
OS X 10.8.5
Digi 002 console
Digi 003 rack (not in use)
Novation 25 sl mk 2 controller
Focusrite Platinum Voicemaster pro
AKG 451 C matched pair
AKG 414 C XLS matched pair
Sennheiser 406 T matched pair
Mackie HR824 mk2
lots of fine guitars
homestudio, retired guitar teacher, enjoying life and recording
Old 05-03-2005, 08:54 PM
kraster kraster is offline
I've had this problem and got around it by partitioning the drive into 40 gig or smaller partitions. Other than that I've never had a problem using USB 2.0 drives didn't even know it wasn't approved!
Old 05-04-2005, 12:41 AM
Slim Shady Slim Shady is offline
They have a whole section of the site dedicated to those types of questions.
Compatibility Pages
more specifically:
Hard Drive Minimum Requirements
and
Firewire Drive Requirements
Old 05-04-2005, 09:32 AM
Since you already have the drive, I would say back up any important info, and reformat the drive. Use Apple drive formatting tool, and the Digi recommendations (journaling off, at least for 6.4 and older), and you shouldn't have any problems.
I mean, you already have the drive, if you back up your data, and do a couple of test sessions, you really have nothing to lose. It's not like it will screw up the hardware, and the data on your main system drive should be backed up already...
002R PTLE 7.1
Old 05-04-2005, 09:43 AM
This may be the case, however your situation is an exception to the rule. It is still in the best interests of users to follow the compatibility documents for information on drives that will work properly with Pro Tools.
Support FAQ
Old 05-04-2005, 02:45 PM
krikoro krikoro is offline
hello mister digitech support, i have a question are you a computer or a human being? you sound so much like a computer
i have another question, can i plug a hard drive to the additionnal firewire plug on the back of my digi002 and use it as a recording drive
Pro Tools 7.4.2pr external hard drive problem citychalkoutline 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-13-2008 08:08 PM
External Hard Drive Problem P Mackey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 07-15-2007 10:38 AM
external hard drive connection problem semicntrldchaos 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-26-2007 11:32 AM
Problem with External Hard Drive Dante13 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-11-2006 11:58 PM
External hard drive problem splendidmike 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-29-2005 12:35 PM
