Old 07-01-2008, 12:59 PM
sjefkevandriel sjefkevandriel is offline
Default connecting presonus firestation to digi 002
Hello everyone,
A couple of years ago i bought a presonus firestation to use as an adat i/o with my digi 002. For some reason it never worked.
- Does anyone have an idea how to connect the units.?
- Do i need drivers and if so which ones?
Please let me know
Regards,
Kenneth
Old 07-01-2008, 01:23 PM
Default Re: connecting presonus firestation to digi 002
Right now i'm using a mac pro running protools 7.4
Old 07-01-2008, 01:29 PM
OddsAre OddsAre is offline
connect the two using two Optical cables. You then need to change in your hardware preferences the master clock to external Optical. Lastly you need to go into your I/O setup and makes sure that you create 8 new inputs routed to 9-16. You should then have your 8 analog inputs of the 002 for 1-8 and the 8 digital inputs or ADAT inputs for 9-16. That should get you started if the Presonus is functioning properly.
Mac Book Pro Retina 2.6 GHz i7 Quad | 16GB | OSX 10.8.5 | Digi 002 | Apogee Rosetta 800/96 | PT 10 | Waves Gold/RevMaxx V9
Old 07-01-2008, 01:31 PM
ps- no drivers needed
Old 07-02-2008, 01:04 AM
I already tried this. When I select optical as a clock source in protools it says that it's " no valid clock source " and the reverts to internal again. It seems that protools isn't able to see my firestation.
Old 07-02-2008, 01:35 AM
chris110000100101001 chris110000100101001 is offline
Have you set the Firestation to stand-alone mode?
The FIREstation can be set in stand-alone mode by pressing the Mixer
and ADAT buttons simultaneously. Stand-alone mode allows the
FIREstation to do two main things: act as an ADAT line mixer and
perform A/D and D/A conversion. The signal plugged into either the
ADAT I/O will be routed to the opposite set of analog ports. For
example, if a DigiMAX were plugged into the ADAT input, the same
signal would be sent to the TRS outputs. The line mixer would also
function, allowing the user to monitor all eight channels.
SMPTE for the devil
Old 07-02-2008, 05:58 AM
Yes I have. I've read the instruction manual and connected evertything as it should be. And still nothing.
Old 07-02-2008, 12:54 PM
Bad lightpipe "cable"?? Or either or both ends not fully seated as those "connectors" are not the best ever.
Presonus Firestation??? nukmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-29-2003 09:22 AM
Anyone Using Presonus FIREstation? brinaddison 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-29-2003 09:55 AM
Presonus Firestation Pete Evick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-17-2003 03:48 PM
Presonus Firestation mjteix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-19-2003 01:18 PM
Presonus FIREstation Mark_Knecht 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-05-2002 04:23 PM
