Old 09-25-2006, 12:21 AM
scottgreiner scottgreiner is offline
Default Hissy Fades
Why do fade files "hiss", and volume automation fades don't? Is there some dithering, double dithering or noise shaping nonsense going on? Did I make a blunder in my preferences somewhere? Is there still a dithered and undithered mixer? Is there a "white paper" about all this stuff?
I haven't had time to hunt down the exact circumstances - doesn't seem to always happen. It could be a 16 bit session thing. I'll post back with findings.
Thanks
HD2, PT 7.1, 192, OS10.4, Dual G4 1gig.
Old 09-25-2006, 04:53 AM
Drew Mazurek's Avatar
Default Re: Hissy Fades
yes. click on a fade and then press command-f. there's a check box in the dialog box.
www.drewmazurek.com
Old 09-25-2006, 07:23 AM
Thanks!
Hmm... forgot about that. It doesn't really change the noise much though.
I discovered that it's a 16bit session, which I haven't done in a long time. It was sent to me as a Digital Performer 16bit session, then OMF'd to ProTools. I tried importing one of the offending 16bit tracks into a 24bit session, thus creating a 24bit version of the same file (bottom 8 bits obviously empty) - no noise in the fade!
How 'bout that.
Old 09-27-2006, 08:08 AM
weird, I experienced the same thing today. 16 bit session, hissy fades, convert to 24 bit hiss gone. Digi, why is this? Just curious.
drew
www.drewmazurek.com
Old 09-27-2006, 09:51 AM
Thanks!
How 'bout that.
Were the 16bit fades rendered by DP and extracted from the OMF or did PT re-create them. That could explain why the import to 24bit sounds differently because PT would make new fades. Or would PT SRC the 16bit fades? That would be pretty crazy.
frank.
PTHDn 2019.6 (OSX10.14.4), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM
Old 09-27-2006, 10:17 AM
in my case i simply did a save session copy and converted to 24bit and the hiss went away.
www.drewmazurek.com
Old 09-27-2006, 01:23 PM
Yes I know but the 16bit ones, did PT create them or did they come straight from the OMF?
frank.
Old 09-27-2006, 06:32 PM
Ginger Ginger is offline
This is interesting because lately I've been thinking the fades don't sound as good as they used to. I figured it was me, but maybe not.....?
Old 09-30-2006, 08:06 AM
Danny Caccavo Danny Caccavo is offline
Adding dither to a 16 bit result is going to add significantly more noise than with 24 bit. So that is why the 16 bit fades are noiser than 24 bit fades.
If you absolutely need to work in 16 bit you can always turn off the fade dither - however, an undithered process at that bit rate can result in some artifacts at low levels that you won't like (hence the dither option in the fade dialog).
I would recommend that you simply convert your session to 24 bit, as others in this thread have.
Danny Caccavo
Product Manager
Digidesign
Very hissy noise floor diondecibels Pro Tools 10 6 02-21-2013 10:23 AM
"fuzzy/hissy" playback mingustoo Pro Tools M-Powered (Mac) 1 09-30-2007 10:01 AM
Hissy music....help. lightning ad Post - Surround - Video 5 02-05-2005 11:22 AM
Hissy Pres on the 24 ajazzie ICON & C|24 2 11-23-2004 01:55 PM
Hissy Talkback mtung ICON & C|24 0 01-23-2002 12:08 AM
