DeckLink HD Extreme II PCIe OR Intensity Pro PCIe?
Hi again
Now I am researching video cards to drop into a current (just slightly updated) 2012 Mac Pro 12 core, along with 2 x HDX cards. wanting to pump any frame rate Quicktime (from within PT) out to an HDMI monitor. they both SEEM to be approved by Avid. http://avid.force.com/pkb/articles/e...ility/en354329 do I get a Blackmagic DeckLink HD Extreme II PCIe (with HDMI daughter board) or Blackmagic Intensity Pro PCIe Anyone here using either of these in a similar configuration? thanks! |
Re: DeckLink HD Extreme II PCIe OR Intensity Pro PCIe?
https://lukehoward.com/ |
see Avid's link that shows it working with HDX-2 |
What am I missing: 2x HDX cards, 1x Decklink card, 1x daughterboard: that's four slots, right?
Daughterboard only needs a backplate in reality.
HP Z2 Xeon 6 Core, Blackmagic Decklink HD Extreme 3D Win10, PT ver.. Latest |
i have surfed the web in vain.... looking for a clear answer to this
If you install the daughterboard backplate it does block the PCI slot behind it, so you would run into trouble running 2HDX, plus BM, plus the stock video card.
I find the daughterboard description a bit misleading though, because all it is is 2 HDMI port/cables attached to a backplate. There is no board as such. It would be relatively simple to cut a couple of holes for the HDMI ports in the rear of the Mac Pro, (but taking to your lovely new apple with a dremel might not be desirable)
so it sounds as if it will be a Blackmagic Intensity Pro PCIe for me. |
is this the correct solution? for Mac Pro 12 core (current) plus HDX-TWO thanks |
If you go with the intensity, you will not get gen locked video playback.
NO Video out PCIe (Decklink) ?? | peterle | Pro Tools 11 | 2 | 06-28-2013 05:18 AM |
Decklink Extreme vs Intensity Pro cards | Picture Start | Post - Surround - Video | 19 | 12-08-2012 10:03 AM |
Decklink pcie protools 9 picture quality | louisenslinproduce | Pro Tools TDM Systems (Mac) | 2 | 03-12-2011 01:47 PM |
Magma PE6R4 PCIe x4 plugging into Intel Mac PCIe x16 slot? | soloan | Pro Tools TDM Systems (Mac) | 2 | 04-27-2010 12:42 PM |
can feat pcie hd accel to pcie x16 of motherboard? | raga2000 | Pro Tools TDM Systems (Win) | 6 | 06-29-2007 07:37 AM |
