record enabling a track gets static hiss...?
002 Rack system on Mac OS x 10.4.7 dual 2.0 GHZ G5
any ideas on what is going on? |
Re: record enabling a track gets static hiss...?
clock issue? more info would help...settings, prefs...
Mac Pro 3.7 Quad Core Intel Mac OS X 10.13.2 PT Ultimate HDX 2019.10 64GB RAM HDX I/O 16x16 Analog HDX I/O 8x8x8 |
what kind of settings prefs do you need to know about.
what can i try to change with the clock settings. i don't have any external midi timepiece type devices.. just the 002 rack and my g5 thanks in advance for your response. |
I believe LE systems can have different clock sources. Hit apple+2 (on the number pad, not the row above the letters). That should open the session setup window. There should be a drop-down menu with a couple of options in it (internal, AES/EBU, SPDIF...) Make sure "internal" is selected under clock source. If that doesn't work, go to your hardware setup. You should be able to change the clock source from there too.
You might also try to trash your prefs if you haven't already. Also trash the digi database folders on each of your drives. Make sure Protools is not running when you do this. After you're done, empty trash and restart. After you've restarted and before you launch Protools, run disk utility and repair disk permissions on your mac hard drive. Hopefully this will help.
track record enable static | joshprotoologic | Pro Tools 9 | 3 | 10-15-2012 08:36 AM |
Static / crackling when record-enabling (w/ Sandra report) | scadh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 11-09-2010 09:00 AM |
Occasional Static/Hiss from M-Audio Fast Track | evenyre | Pro Tools M-Powered (Mac) | 0 | 06-05-2009 01:47 PM |
Record enabling an Aux track with Reason plug-in | Mean Green | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-23-2004 02:10 PM |
Problem when record enabling a track | BlackOctopus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-09-2003 10:15 PM |
