Digital input split
Hi All.
I was wondering if there is a way to use 1 input rack to feed 2 consoles (ie: FOH and Monitors). Any help is much appreciated Cheers, Gerard. --- I am here: http://maps.google.com/maps?ll=-38.385743,144.839980 |
Re: Digital input split
2 Consoles connected to one stage rack is not supposed on the VENUE system.
I think it is possible in a couple of way's, however, it isn't that elegant. Firstly, I believe that although the digital stage rack isn't sending a Madi signal, some success has been had using an RME Madi interface to split signals, which console controls the Mic pre gain's I'm not sure, but I would search these forums as I am sure it has been discussed. Secondly, using a Madi card out from the FOH/Mon to a madi card input on the other console with the inputs reversed to HDX inputs would allow you to access the same material, gain changes on the first console would effect both desks though.
I had that thought, which I would configure to be that monitors have gain, but it is probably easier and cheaper to just use analog splits.
--- I am here: http://maps.google.com/maps?ll=-38.385652,144.840183 |
My vote...is for the analog split. On occation, I do shows using the MADI split. Fairly simple...honestly. Connect stage rack to primary VENUE (will have gain control, obviously). Then use the madi card to deliver the split to mon...or wherever the split is needed. You can either use fiber or BNC's. It is great, because you can incorporate this with other digital consoles...I've done it with a Yamaha PM5D and also DiGiCo SD8. Worked like a charm each time. The hardest part was explaining how it worked to the producers...Hahaha
Ken Miller, Jr. Audio Engineer Southside Baptist Church | Warner Robins, GA | VENUE Profile 96X64 with MADI Option | ProTools 7.4.2 HD3 Accel PCI | ProTools 10 Native | MacBook Pro 17" OS 10.7.1 2.3GHz Intel Core i7 8GB Ram | Mbox 2 Pro | Mbox 3 Pro | Motu 896mk3 Hybrid |
Using a single input split into 2 | the-11 | VENUE Live Sound Systems | 5 | 01-21-2018 05:26 PM |
Can I split input and output engines? | ElSaxiDad | Pro Tools 11 | 3 | 10-17-2013 05:45 PM |
Digital split | Piitzei | VENUE Live Sound Systems | 5 | 10-28-2012 10:09 AM |
Is there a way to use a digital input at 96k from a digital output at 48k? | rockguitarist1255 | Pro Tools 10 | 3 | 01-04-2012 05:48 PM |
Digital Output from 888/16 isn't compatible with Digital Input of TC M2000 & PCM 80 | beerbr | Pro Tools TDM Systems (Mac) | 0 | 11-02-2000 08:01 PM |
