Bounce keeps stoping ( -9073 )
I just bought a mac Mini everything seems to be running good my only problem as of now I am running my Lacie D2 hard drive to the Mac via USB due to the Mac Mini only having 1 firewire input and everytime I boucne a session the bounce keeps stoping and giving me a message: Cant get audio from drive fast enough.. something about the bandwidth or CPU load ( -9073 )
do I have to get a firewire port or is there another way to daisy chain or somthing..Help!! |
Re: Bounce keeps stoping ( -9073 )
Can I plug my Lacie D2 into one of the Firewire inputs on the rear of the 002rack and run the rack into the mac mini..is this ok
Help!! |
newbie I know but I need some help!! come on fellas.lol
If you can, but Daisy chain the 002 off the back of the drive is the proper way. Don't use the 1394 ports on the 002 for drives or anything other than connecting very small cameras or charging devices.
USB is usually too slow for recording. Also Setup > Playback Engine > make sure your DAE Level is NOT level 8. Bring that back to level 2, and set the H/W Buffer to 1024 or higher if possible. Does this help? |
on the rear of the Lacie drive i only have 1 fire wire 400 input ( reqtangle looking port 400 I beleave ) but it does have 2 800 ports can I run the 002rack into the 400 and use a 800 to 400 cable fire wire cable to run the harddrive to the mac ( its 800 on the harddrive side and 400 on the Mac mini side ) or should I just buy a firewire 400 hub ....this is a new problem for me thanks for the help
click link below to see the rear of the d2 hard drive
http://www.lacie.com/imgstore/produc..._d2_triple.jpg |
I had the similar situation. I have a LaCie D2 500 GB, Macmini (G4) Digi 002R. Had problems when daisy chained through Digi002. Solution: Firewire port for the Digi002, USB port for the LaCie. Now it runs 24/7, without stopping.
space bar not stoping recording | stephenharvey | Pro Tools M-Powered (Win) | 0 | 12-27-2010 10:43 AM |
Sync stoping to record | nk3000 | Pro Tools M-Powered (Mac) | 0 | 01-13-2010 03:07 PM |
DAE error -9073 I can't bounce to disk | Mic Lungz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-23-2006 11:29 PM |
9073 and Permissions error in Bounce to Disk | munsongs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-01-2006 08:18 PM |
DAE unable to bounce file???-9073 | Dr. J | Pro Tools TDM Systems (Mac) | 1 | 06-16-2000 04:23 PM |
