Old 06-24-2009, 09:42 PM
Roseland Music Roseland Music is offline
Default Hard drive won't format.
I just bought a Mbox mini 2, upgraded my Macbook Pro with Leopard, and added a Western Digital external hard drive (1 tb). I can't format the hard drive. Also, Pro Tools won't open the initial "Demo Session". Needless to say, I am a novice at this, although I am a professional musician. Any and all help is very much appreciated!!
Old 06-25-2009, 01:32 AM
The Dougfather The Dougfather is offline
Default Re: Hard drive won't format.
Can you provide info that related to not being able to format the drive, errors etc?
You've gone to disk utility, selected erase and chose Mac OSX Extended (Journaled)?
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 06-25-2009, 06:46 AM
Mark Reis Mark Reis is offline
Is it really a 1 TB drive or 2 500GB as a single volume using some proprietary WD driver?
This would be the first place I'd look barring any other missing information.
Mark Reis
Sound Designer
Old 06-25-2009, 02:07 PM
Hey guys. Thanks for the help!
When I try to format, I go to disk utility-choose the top HD icon (there's two) from the left column- then choose erase, journled, then I click erase. The error says "file system formatter failed". This WD is, in fact, a 1 tb drive, by the way.
Old 06-25-2009, 02:56 PM
robo6675 robo6675 is offline
Have you tried other formats? Also are you running pro tools while doing this or any other application?
MacBook Pro (silver) 2.5 GHz Intel Core 2 Duo - 4 GB RAM - 10.6.6 - PT9 - 003 BLA sig mod
Terrarium
HD3 Accel on a PowerPC - OS 10.5.7 - PTHD 8.0cs2
(3)192/SYNC IO/CS HEDD192/Studer A27/Neve 48 Ch. VR console
Old 06-25-2009, 05:26 PM
ChuckS ChuckS is online now
Instead of going to erase, pick the partition tab. On the Volume Scheme drop down, change it from current to 1 Partition. Click Options button and select GUID, then OK. Make sure the Volume Information is correct then click apply.
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
Old 06-25-2009, 07:49 PM
I didn't try any other formats, only what was instructed, as I am walking on eggshells with this stuff not knowing if the wrong button could possibly make something explode!! I got this to make demos, thinking it would be reasonably easy to get up and running. I'm invested now, so it's no turning back, in my mind. That said, I can't even get the stinking hard drive to format. To my knowledge I do not have any other apps going. When I first tried to format I think I did have PT running. This time I just had the HD going to no avail.
Old 06-25-2009, 07:51 PM
This sound like the right move to everybody here? No offense, Chuck. Thanks for taking the time!
By the way, the Western Digital is the "Home Edition"...for what it's worth
Old 06-26-2009, 04:14 AM
As long as you don't have the system drive selected - no problem. That would be the one that has the MacIntosh HD volume listed underneath it.
Look here: http://wdc.custhelp.com/cgi-bin/wdc....i=&p_topview=1
In the WDC docs they select Apple Partition Map instead of GUID. If you were planning on using it as a system drive (boot volume) someday then GUID, otherwise APM is fine.
how to format my hard drive wallsstreet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-12-2007 09:27 AM
If i format my hard drive.... ANTDEM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-30-2006 06:57 AM
How can I format my hard drive on my mac? ShyStylz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-21-2003 06:05 PM
hard drive format? HFS or HFS+ (001) soundboy69 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-04-2002 03:31 PM
Hard drive Format Maxz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-02-2002 11:14 PM
