Pro Tools 10 Wont Launch
I have recently built a new PC. All working fine until I came to re install and use pro tools 10 with my eleven rack.
I right click and launch as admin and hold the "N" button, when the box appears on the screen it does not show my eleven rack as an asio device. The only option that is there is "Realtek Asio" and then I get a DAE error -6010 was encountered. All the drivers are up to date and the latest update for PT 10 is done, no missing drivers on device manager and all updated by their vendors. I'm clueless tbh my last PC was Windows 10 home edition and it worked ok. I'll post my PC specs and any advice would be appreciated. Thanks In Advance, James Custom Build PC Corsair 780T Full Tower Case Corsair RM850 850 Watt Power Supply ASUS ROG MAXIMUS IX Motherboard Intel I7 7700K 4.2ghz Processor Corsair Hydro Series H100i V2 Liquid CPU Cooler 64 GB Corsair Vengance DDR4 Ram Gigabyte AORUS GeForce GTX 1080 TI Xtreme Edition 11264MB GDDR5X Samsung 1TB 850 EVO SSD Seagate Barracuda 2 TB 7200 RPM HDD BluRay Drive Onboard 7.1 Realtek Sound Windows 10 Pro Last edited by SARGE994; 06-07-2017 at 11:39 AM. |
Re: Pro Tools 10 Wont Launch
Which version of the Eleven Rack driver is installed? Should be listed under device manager.
PT10.3.10HD(Tyan s2932 [8core Shanghai 2.7GHZ] 32GB,Win7 SP1); PT10HD(Tyan s2892 w/10GB, Win7 SP1);PT8HD(Dell 690 quad Xeon 3.0, 8GB, Win7,192 I/O, 96 I/O);MacBook Pro: 11R, Apogee Element 46, Focusrite 8PreX PT HD 11.3.2; Mac Pro 3.47 Hex 32GB, OSX 10.12.6/L10.4.2;L9.1.8, 2.64TB; G5 D2.3 4GB, 10.4.11/L8; 12c MP 2.66/32GB PT12.4; Structure, GigaGS3, Kontakt 5, Garratin, Sibelius 8.7+, Finale26,EMU,Vegas Pro 16-10/; RME HDSP9652,MOTU 2408 MKIII/1224/308, FX,Kurz,L5s,Strat,ASAT,JB,Zon |
The latest one from the avid web site, 1.1.11
Does the Eleven Rack and that driver work for anything? Most likely explanation of all this is no. Start by ignoring Pro Tools. Can Windows or other audio apps see it? Can the Eleven Control panel see it? Is the USB cable connected properly? etc.
when I switch the eleven rack on I can play stuff through my monitors connected to eleven rack, guitar works, youtube, music on PC it just does not show up in that window when starting PT.
Bit more info, last night i tried asio4all this did allow me to launch pro tools but eleven rack still did not show up in the playback engine within pro tools.
So I did a total fresh install of Windows 10 to see if that would work now im back to square 1 LOL |
Not sure why you installed the ASIO4ALL driver, but I would un-install it until Pro Tools can "see" the Eleven Rack driver. I have never needed ASIO4ALL for anything. I have computers with both SoundBlaster drivers and Pro Tools drivers, but never used ASIO4ALL. FYI, Pro Tools does not like some soundcard drivers.
If you do not have any yellow exclamation points in device manager, I would try this: "Disable" the Realtek feature (usually a built-in motherboard sound chip) in device manager. Then go into programs and features (from control panel) and uninstall Eleven Rack. Then re-install the Eleven Rack driver. Be sure the Eleven Rack itself it turned on and initialized before you turn on your computer. If the Realtek driver shows up when you start Pro Tools, it has not been "disabled."
Yes do all that ^^^. Reboot the computer.
If the Eleven Rack driver still does not show up uninstall and reinstall the eleven Rack drivers (with the Eleven Rack disconnected as always, don't let Plug and Play mangle things). |
asio4all is no longer on this install and never has.
Just tinkering now see if I can sort it. Will post an update later, thanks for the input. |
Try not using the 11 Rack as a Windows audio interface and see what happens. Windows is probably grabbing the 11R before PT has a chance to see it.
Por tools LE 7.0 wont launch | Starhead | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-03-2009 07:12 AM |
pro tools wont launch | kguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-10-2008 10:11 AM |
Pro Tools WONT LAUNCH! - All of a sudden !?! | gollywillickers | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-14-2006 05:55 AM |
Pro Tools wont launch!!!!!! i am going crazy...... | woodbeatz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-23-2004 05:00 PM |
pro tools r2 wont launch | ovo | Digidesign Hardware & Software | 0 | 12-26-2000 07:05 AM |
