Re: Drifting Video offset
Custom i9-12900K, 64GB RAM, W10 Pro, PT Ultimate 2024.03, HD Native, OMNI, Digi 192, UAD-2 Octo; Mac Pro 12-core 3.46, 64GB RAM, Mojave, Logic Pro 10.5.1, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Mojave, MOTU 8-Pre-ES, Pro Tools 2021.7 |
Hopefully Avid is serious about a lower cost all-in-one I/O interface that includes sync. Will take the SyncHD out of the picture for smaller rigs.
~Will |
So does everybody pull out their Synchecks between each project, or do you just eye it?
Also after lunch/breaks. Why this changes I do not know. Without bringing up bashing - Nuendo is consistent, as is the OS video playback. Not a 3 frame span that is clearly visible. So I wonder what is causing the issue internally with PT - and why would a Sync HD be needed to get the computer to ouput its video and audio streams at roughly the same time. LCD frame offset etc aside... something is wrong in the internal pipeline for sure. And it seems like a different pipe after every session load... (And I have been to several studios and edit rooms out of house where there are no Sync IO/HD and it is stable and seems consistent throughout. +/- the quarter frame as listed.) |
Just came back from lunch break to find that PT video offset in the open session had shifted 90ms over lunch break.
#16
As Frank wrote, only a genlocked system will be 100% accurate when offsets are setup correctly. The big downside of a genlocked system is that a connected PT SYNC unit introduces additional latency when you hit play. Very annoying.
#17
@Fish Horse - it seems to be a different issue. This used to be better in older versions, i.e. one offset for one project worked (actually for one codec for all projects). For me it was 35ms.
It now changes on every re-open, or even over breaks. From -50 for example to +80. And stays at that (+/- 20ms) I am not talking about slight drifts of 1-2 frames on each play. I have +/- half a frame. I'm talking about actual variations of 4 frames for every time a session is reloaded. Once loaded, THAT new offset stays constant until next load (except for lunch breaks). I am thinking this might have to do with some kind of power-saving issue of an idle system too, due to it cropping up over a longer break. Still trying to track that down... |
#18
I don't experience that. Once I find the offset for a certain codec and format it's consistent.
~Will |
#19
At first I thought it was because of me working through an input-monitored re-rec track (and had the Auto low-latency off setting deactivated in the mixer for that track). But it happens in a plain edit session with hardly any CPU taxing (25%ish), no re-rec bussing too. Something has been screwed up and the OP post seemed like a similar issue. |
#20
Just an update on interesting findings:
I think it may be linked to processor Speed Stepping (EIST for Intel i.e.). These I usually have disabled (re DAW OS optimization), but it seems that when they are enabled while loading PT or a PT Session, they throw off the internal latency calculation. Have to delve deeper into this but I have been pretty consistent with offset values for this one session now over the last week - always making sure I have my right CPU profile loaded when opening PT/session. Other things I have done also: changed PhysX away from NVIDIA GPU to the CPU and disabled some of NVIDIAs "auto" choice on which GPU does what etc. Might have been a combination of things. Hope it helps the OP or others... |
does video offset apply to in the box video? | cananball | Post - Surround - Video | 5 | 04-03-2011 07:05 PM |
Video sync offset | samplaire | Post - Surround - Video | 9 | 11-16-2010 05:50 AM |
Video sync offset changes | Studio Studio | Pro Tools TDM Systems (Mac) | 0 | 09-15-2008 06:33 AM |
drifting sync mark on da video trak | HOBS6 | Pro Tools TDM Systems (Mac) | 1 | 07-12-2005 03:00 PM |
How best to calibrate DV video offset | One Track Music | Post - Surround - Video | 5 | 10-31-2004 11:52 PM |
