Odd plugin behavior.. Video provided
Pro tools 2018.12.0
OSX HS 10.13.6 I've never before seen this behavior.. and have no idea what could be causing it. If I open a plugin, then click another plugin, the new plugin displays and then closes. Sometimes I can close the first plugin and open the second plugin, and it closes after about a second or two. The behavior however is intermittent. Here is a link where you can see a short video detailing what is occurring. http://ztrack.net/plugins.mov Any help appreciated.. |
Re: Odd plugin behavior.. Video provided
Do you have any hardware controllers setup in peripherals? MIDI or Eucon? Is Eucon turned on?
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
I just updated the UAD software.. and so far things seem normal, but the issue was happening on all plugins and it was not consistent, so to soon to tell if that solved the issue. It seems illogical that it would since the issue started yesterday and nothing has been changed. Thx for the reply |
Are you running the latest Eucontrol? Turn off Eucon if it happens and see if it stops
thx |
And if you are using PT Control, you have to stick with with 19.5 (because you can't downgrade the Control app due to Apple's policies.) What you need to do is go through all the options in Eucontrol that govern how windows close and open. That's what your problem is. uncheck the stuff you don't want to happen. General tab, left column and lower half of right column.
Odd video behavior | DonaldM | Post - Surround - Video | 22 | 05-09-2017 08:58 AM |
Is Pro Tools Crashing? Link provided with video. | tomswhittaker | Windows | 0 | 04-03-2013 07:59 PM |
strange video behavior... | BaileyBass | Post - Surround - Video | 4 | 09-04-2011 12:25 PM |
Nasty Plugin Behavior | Plectrum | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-13-2005 11:21 AM |
Nasty Plugin Behavior | Plectrum | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-12-2005 11:10 AM |
