Old 01-05-2004, 05:40 AM
morganlann morganlann is offline
Default problem with mu digi002r hardware
i have a pb since friday. My digi002r hardware commuts on "mute" and i can't do anything. It is as if it was turn of...???
i check all my connection (firewire, electric, ...), but nothing change. Some times it works for 10mn or less, and it turns off alone....
I can't uncerstand what's happen. DO you think it's a hardware probleme or it could be something esle??
thank's!
Old 01-05-2004, 05:43 AM
feliponk's Avatar
feliponk feliponk is offline
Default Re: problem with mu digi002r hardware
Defective unit?
Felipe Gonzalez A.
Avid ACSR Elite
Dante Certified
http://felipousismix.wix.com/felipousismix
Custom Mac Pro OSX Sierra | Windows 10 Pro 64 | ProTools HD 2019 | Pyramix XI | Merging HAPI ADA8 | MBox 3 | UAD Quad PCIe | Avid Artist Mix | Kali LP-6 | Presonus Temblor 10 | Universal Audio, Slate Digital, McDSP, Fabfilter, Plugin Alliance among other plugins
Old 01-05-2004, 05:45 AM
pearhaps!!
but i used to work well for a month. So I don"t understand!!
Old 01-05-2004, 08:25 AM
Ni idea??
Could it be something else than an hardware problem??
problems began when i had to my system an "evolution MK449c" keyboard using usb plug. I program it to control protools so i declare it as an control surface into protools.
I'me going to go back to my dealer because it is garanty, but i hope there will be no problem...
Old 01-05-2004, 11:26 AM
Daniel Reis Daniel Reis is offline
This problem just happend to me now ... i was browsing the DUC for anwsers and found your post ... i was also working fine for the past 30 days and today i was mixing and suddenly my oo2r went to mute and lost sample rate ... protools dialog says that it lost comunnication ... it happend also later when i kept trying to put it to work it reboots my pc .. now this same problem is happanig also outsaid protools .. when I boot my cpu windows xp cames up ok digi is ok then if i wait 5 minuts or less looking at digi 002r it losses comunnication alone ...
sorry my english I´m from Brazil .. please help!?
my pc is a
Atlon xp 2,6+
Soyo Dragon Ultra Platinum
chipset via KT400 fbs333
1GB Ram DDR 333
Video Nvidia Gforce 4 64mb
2 ide 7200 rpm SEAGATE baracuda IV Drives
Belkin firewire PCI card
Digi 002 R
windows XP SP1
protools 6.1.1
thnaks,
Daniel Reis
www.danielreis.com.br
Old 01-05-2004, 01:02 PM
feliponk's Avatar
Ok guys, take you hardware and go to your dealer, it must be under warranty. If the unit is defective, they must replace it for a new one, that's it. Good Luck
Que estén bien
Felipe Gonzalez A.
Avid ACSR Elite
Dante Certified
Old 01-23-2004, 11:18 AM
I'm becoming crazy!!!
i returned my digi002 rack 2 weeeks ago, it returned to ireland, and today i received a call that says i can take it back, it have been repared!!
great!!
i plugged it very carefully, then i turn it on : "bzzzzzzzz", and that's all....
nothing more it turned off 1 second after i turned it on, and now nothing happens, as if it was an electric problem...
I leave in france, which is 220 V, 50hz, could it be because off digidesign in ireland used an other plugg??
QUICKTIME 7.3 and DIGI002R Problem alx002 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-23-2007 08:37 AM
Please Help!!! DIGI002R Hardware Not Recognized msds1981 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 05-30-2006 05:43 PM
Help!!!! Problem with digi002R!!! funmusical 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 08-19-2005 07:49 AM
new problem with digi002R supafuzz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-27-2005 04:39 PM
Hardware Exchange Mbox to Digi002R DAE error -6087 Dalanshin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-01-2005 09:59 AM
