Old 12-14-2010, 12:26 PM
garret garret is offline
Default Switching between 4 protools (keyboard and monitors)
So we are setting up a four pro tools system with a 32 fader d control. We are looking into how we will switch between each system for the mouse and monitor control. Obviously the D control works fine with Satellite link so switching between the four machines there is working fine. We will have four Monitors; one for each machine. We are looking into Synergy which seems like a good option and seems to work but I'm wondering what anyone here is doing to switch on their system. Any thoughts would be appreciated.
Thanks
Garret
IMDB
Old 12-14-2010, 12:31 PM
dr sound's Avatar
dr sound dr sound is offline
Default Re: Switching between 4 protools (keyboard and monitors)
Try this:
http://www.newegg.com/Product/Produc...scrollFullInfo
or any other IO Gear KVM stuff
Look Here at their site:http://www.iogear.com/solutions/kvm/?view=4port
Marti D. Humphrey CAS
aka dr.sound
www.thedubstage.com
IMDB http://www.imdb.com/name/nm0401937/
Like everything in life, there are no guarantees just opportunities.
Old 12-14-2010, 12:54 PM
O.G. Killa's Avatar
O.G. Killa O.G. Killa is offline
Thanks
Garret
With synergy you'll still need four LCD displays (one for each computer). Marti's KVM switch will allow you to do it with 1 display (although you can only view one at a time).
Synergy is really cool in that it turns your multiple computers into what feels like ONE computer with multiple monitors. But, you still need a monitor for each computer. If you are ok with having 4 monitors above/beside your Dcontrol then go for it.
I've used the IO gear KVMs for a while in several different rooms. They work pretty well and they have single monitor and dual monitor versions.
Derek Jones
Sound Engineer / Producer / Composer
Derek Jones Linkedin
Megatrax Recording Studios
Megatrax Studios Yelp Page
A-list Music Artist Page
Old 12-14-2010, 01:06 PM
dr sound's Avatar
That is why you use one of these splitters on each video out:
http://www.iogear.com/product/GVS162W6/
Then send it to your KVM. That way you can have the best of both.
aka dr.sound
www.thedubstage.com
Old 12-14-2010, 01:35 PM
Vedat's Avatar
Vedat Vedat is offline
Quiet Art Ltd.
I have used Teleport and it's very efficient.
http://abyssoft.com/software/teleport/
Again, you need separate monitors for each computer.
Vedat
WaveRider + Defaulter (now with LKFS)
QuietArt.co.nz
Catchin' SYNC app
Old 12-14-2010, 02:52 PM
Craig F Craig F is offline
http://www.avocent.com/Products/Cate...M_over_IP.aspx
not cheap but highly flexible
Thank you,
Craig
Old 12-14-2010, 05:23 PM
antonis's Avatar
antonis antonis is offline
Synergy has been amazing for me in a 3 computer - 3 screen setup. The only drawback that I find is that some PT shortcuts work only to the computer that acts as the server (has the keyboard and mouse connected to it). But it is mostly the case for the shortcuts that have the cmd key in their combo. And that is in a three mac setup. I am not sure how would it be with PCs.
And by the way, without hijacking this post, if anyone has experienced the same problem and has a solution to it i'd be happy to know!
Old 12-15-2010, 01:28 AM
Thanks a lot guys. Much appreciated
Garret
IMDB
HTML code is On
Switching between two sets of monitors on Omni ? chrisdee Pro Tools HDX & HD Native Systems (Win) 13 08-12-2012 11:44 AM
Switching keyboard focus via key command? Nielsy Tips & Tricks 8 10-25-2010 05:16 PM
monitors pop when switching analog insert tfricilone Pro Tools TDM Systems (Mac) 0 11-04-2007 12:06 PM
pop in monitors when switching to alt. speaker dkroger ICON & C|24 6 07-07-2005 03:32 PM
Switching Between 2 Monitors on a Control 8 John Pisciotta ProControl, Control|24, Command|8 2 02-08-2005 10:20 PM
