Old 01-29-2005, 07:40 PM
Dalanshin Dalanshin is offline
Default Hardware Exchange Mbox to Digi002R DAE error -6087
Hello,
Once upon a time I was running Mbox for almost a year with no problems.
Then I decided I needed a few more options.
So I did a hardware exchange through Sweetwater.
Mbox became a Digi002R. Cool.
I went from LE 6.1 to 6.4
Installed an Adaptec 4300 firewire card.
Now I have problems.
When I try to record, it stops after about 2 seconds and says DAE error -6087.
Every, single, time.
I have tried changing playback settings.
I switched back to the Mbox and I had no problems recording. Mbox still works fine.
So the problem seems to be related to the digi002R, and perhaps the firewire.
But that's just a guess.
I have no clue what to try next, other than saying "to hell with it" and staying with the Mbox (I have a time limit to send it in to Digi).
I can't afford a new computer at the moment, so I have to make due with what I've got I need to know how to make it work, not what other gear I should have. I can't accept that my system would work with the Mbox but not the Digi 002R. LE is LE, so why is the Digi002R interface making problems?
Thanks for any feedback,
Nikolai
Studio IMP System Details (am I missing any important bitz?):
AMD Athlon, 1.67GHZ, 512MB Ram, 111GB Main drive, 114GB Audio Drive, Adaptec 4300 firewire card.
Old 01-30-2005, 04:48 PM
Aussie Scott Aussie Scott is offline
Default Re: Hardware Exchange Mbox to Digi002R DAE error -6087
Check your IRQ allocation in device manager - make sure your FW4300 is on it's own IRQ - if not switch it to another slot.
Also what Mobo are you using? Do a search here on the make/model and see if there are any compatability issues. While you're there, do a search on the error# in the answerbase as well as here. That may help you hone down the actual problem. Hope that's useful
Cheers, Scott
"...I asked you not to tell me that!"
Old 01-31-2005, 05:40 AM
Thanks Scot, I'll check on the IRQ and Mobo.
One thing I noticed on the compatibility page for the digi002r is that it requires 2.0 GHZ.
The Mbox only requires 1.3GHZ. So that's why I was running mbox with no problems!
Apears I'll have to figure out how to upgrade the processor speed (if I want to keep the didgi002r).
Any suggestions for this from tech savvy types are welcome.
Yours,
Nikolai
PS: Is there an alternate way to identify a motherboard if you can't find the info printed on the board??
Old 02-01-2005, 09:59 AM
I was mistaken about the processor; I have do an approved processor.
-Nikolai
Hardware exchange program from Mbox 2 pro to HD Omni/HD system ? chrisdee Pro Tools TDM Systems (Win) 15 11-26-2010 08:28 AM
Mbox/002R hardware exchange? jojo wuzaman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-26-2007 10:09 AM
Hardware Exchange MBox 2 Pro BJMarch58 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 02-08-2007 06:02 AM
Mbox 2 Pro Hardware Exchange? mcr3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-18-2006 07:40 AM
Digi001 - MBOX Hardware Exchange Craiger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-14-2005 10:46 AM
