Old 01-06-2005, 09:07 AM
Dr. Bockman Dr. Bockman is offline
Default Protools fragmenting files small and large
Protools LE (002r) seems to be fragmenting every file that I save to my external Seagate firewire drive. Whether it's a small .pts file or a large audio file, every time I save and follow it up by analyzing the hard drive for fragmentation, the files are fragmented. I discovered this while having some serious problems just getting Protools to run smoothly. When I try to open a session where the .pts or any of the audio files are fragmented, Protools slows to a halt. At best, I get buffer under/over flows.
Dell Inspiron 8200 Laptop 1.6 GhZ P4
512 RAM
Protools LE 6.4
Digi 002r
30 G internal system drive
150 G external Seagate Firewire drive
I have been running Protools LE (now updated to 6.4) on my Dell Inspiron laptop for about 2 1/2 years now. Not until recently did this start happening. The 150 Gig Seagate drive is brand new, and I have only used up about 13 Gig.
Another thing I noticed (but may be unrelated) is that whenver I close Protools, there is a series of exception notices that fire off, each of which I have to hit ok on to finish closing Protools. Each error notice regards memory that could not be read from location ... 4ea4dd8d or something similar.
I have unistalled Protools and reinstalled. The errors upon closing do not occur on Protools LE 6.1, but start to occur again when I upgrade to 6.4.
At this point I realize that it could be my decrepid WinXP system. I am still able to have fairly smooth sessions and record 10 tracks at a time (8 analog and 2 spdif) but I have to defragment my hard drive every day and sometimes multiple times per day. It takes time and I am worried that it will take its toll on the hard drive.
I have searched the DUC, answerbase and googled, but haven't found anything yet. It may be that I haven't found the right words to search with, but I figured that if anyone knew anything about this, someone on this forum would.
Any help will be greatly appreciated.
Thanks
Wil Reeves
We are who we pretend to be... -KV
Protools LE 6.4
Digi 002r
WAV Files too large? MisterLbx Pro Tools M-Powered (Mac) 1 03-22-2012 06:35 AM
ProTools creates large audio files at random (2GB) RoyalParks 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-03-2005 11:42 AM
Advice pls: which DV rec to buy? Small or large DV thevoicefactory Post - Surround - Video 3 01-27-2005 05:58 AM
1394 cable (large vs small) VanDerGraf 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-01-2003 04:02 PM
large or small diaphragm condenser for drum overhead, and why? Siberian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-21-2003 08:55 AM
