Old 04-15-2007, 05:03 AM
zeh zeh is offline
Default d24 / 888 IO / windows xp / standalone asio driver (7.3)
Hi There,
i borrowed a digidesign d24 card (also a dsp farm card) with the 888 io interface from a neighbour.
my problem is, i cant get it to work. i installed the driver and in my system settings hardware panel it shows up correctly (digidesign d24). its using dalwdm.sys. if i start some application (lets say propellerhead reason or ableton live) iam able to select 'asio digidesign' driver. if i do so, the computer hangs for about 5 seconds and says the driver could not be loaded. is there any clue? do i have to insert (i already tried) the dsp farm ? is that some hardware error? is there a way to 'test' the hardware? so, driver is loaded, interface is connected, but it doesnt work any suggestion?
so long
-chris
Old 04-28-2007, 08:30 PM
Sugarnutz Sugarnutz is offline
Default Re: d24 / 888 IO / windows xp / standalone asio driver (7.3)
I think you will need the driver version 6.4.1 for Mix systems as this was the last version that supported the D24.
Gigabyte z390 Designare
I9 990K 4.7 GHz
64 Gb of DDR4 3200
Gigabyte RX580 8 Gb
Win 10 Pro
15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM
512 Gb Flash Drive - OS X 10.14.6
HTML code is On
Original Mbox Standalone Driver for Windows 7 Kudy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 04-23-2013 05:43 PM
Problems with Standalone ASIO Driver version 8 for 003R Kurt Briggs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-14-2011 08:32 AM
Problems with Standalone ASIO Driver version 8 for 003R Kurt Briggs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-13-2011 10:39 AM
Original MBox - Standalone Driver for Windows 7 toastyt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-06-2010 12:52 PM
PTLE Standalone ASIO driver simply refuses to work Statick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-13-2006 10:02 AM
