AAF/OMF Export Link to Source Media is Greyed Out
Hello,
I am trying to export an AAF or an OMF (which one does not matter for me) for continuing to work in Nuendo since the studio runs Nuendo. The audio files of my project are quite huge. Therefore, I don't want to export all audio again, but link to the files. Another reason is, that I have reduced disk space. Copying everything would not fit on the disk. Now, when I select "Export AAF" or OMF the option "link to source media" is greyed out. I can only select to "Consolidate". Any suggestion how I could change that? Help is so much appreciated. Thanks, S |
Re: AAF/OMF Export Link to Source Media is Greyed Out
Try unchecking 'Quantise edits to frame boundaries' if it is checked. You will need to also uncheck 'Enforce Media Composer Compatibility' to make this possible.
If that doesn't work then possibly the audio files are of a type which are not suitable for AAF/OMF. Tell us: What version of PT are you running? What audio file type are you using (wav/aif)? What bit depth and sample rate? Are you using interleaved for stereo files or split mono? |
I had this same problem. My issue was that I had interleaved files in my session. AAF doesn't support interleaved files.
.. did you get an error telling you that "Interleaved" ?? or did you have to figure it out for yourself ?? i am waiting for the day that Programmers put Logical Messages to Issues .. maybe when hell starting getting a cold spell
Clearly the stakes are much higher in those situations than they ever will be with Pro Tools.
AAF Link to Source Media not working | PandaHouse | macOS | 2 | 03-02-2013 07:24 AM |
Can't choose "Link to Source Media" | mrbobb | Post - Surround - Video | 7 | 07-25-2012 01:57 PM |
OMF Protools 7.3 Cannot link to source media | ErockZ | Post - Surround - Video | 25 | 05-01-2007 03:12 AM |
Link to source media greyed out in digitrans? | Frank Kruse | Post - Surround - Video | 1 | 09-12-2005 08:48 AM |
Export Selected is Greyed Out | cheerio | Pro Tools TDM Systems (Mac) | 2 | 02-21-2005 07:12 AM |
