Old 11-08-2004, 10:32 AM
MUSIKxDRUMR MUSIKxDRUMR is offline
Default Recording via Optical Question
Hello,
I have been triing to record from a Roland VS-1680 track recorder into my PT LE 002 via Optical cables. I basically just want to record the Roland tracks straight into PT for mixing and mastering purposes. BUT for some reason I cannot configure this to work??? So far, I've only been able to get any audio when PT is set to recieve the audio from the S/PDIF, which is only 2 tracks. But I need the Optical setting because I need 8 channels of audio.
I think it was something to do with the I/O setup and/or the clock source. I don't know if I need to set to my internal clock or the source clock? Does anyone know how to configure PT to record via Optical???
*Also, do both, in and out, Optical calbes need to be used? Right now I'm only using 1 cable... from the out of the Roland to the in on the Digi002. Thanks--
Old 11-08-2004, 10:40 AM
spkguitar's Avatar
Default Re: Recording via Optical Question
From what I've read, the optical on the 1680 is S/PDIF only, not 8 channel ADAT. You can only do 2 digital outputs at a time with it.
Old 11-08-2004, 10:52 AM
Wow, thats interesting. I never even thought about that posibility. I'll try the Roland Forums and see what they have to say about it. Thanks--
ADAT optical recording skirby 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-18-2010 05:05 AM
Recording SPDIF and Optical modernart 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-24-2008 10:28 AM
Optical Recording S.L.R 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-06-2007 09:38 AM
recording and monitoring thru optical stickytapenrust 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-26-2004 08:11 AM
jitter in using optical recording Chaasm71 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-08-2003 12:10 AM
