Old 11-05-2009, 09:02 AM
gbross gbross is offline
Default Pro Tools 8.0 LE on 32 bit Windows 7 - can't install
I had to redo my PC. I upgraded it to Windows 7 32 bit.
I previously had PT 8.0 LE running on my XP machine.
I downloaded PT 8.0 LE Upgrade from my Digi Account.
When I try to run setup nothing happens (the hour glass spins, then nothing)
I have a MBOX Pro - Firewire.
Do I need PT 7.* loaded before I run PT 8.0, or is PT 8.0 a stand-alone install.
Also can PT 8.0 run on Windows 7 64 bit?
Thanks for your time.
Old 11-05-2009, 09:26 AM
hue hue is offline
Default Re: Pro Tools 8.0 LE on 32 bit Windows 7 - can't install
I'm using Windows 7 and 8.01. It installed fine for me. Which version of Windows 7 are you using? As far as I know only business and ultimate versions are supported, though Windows 7 generally isn't officially supported yet.
Intel i7 4770
Dell XPS 8700
16 Gig DDR3
1 x 1TB System Drive
1 x 320Gig Seagate HDD
1 x 500Gig Seagate HDD
UAD-2 Solo
Steinberg UR44
KRK RP5
Windows 10 Pro. 64 bit
Sonar Platinum
Cubase 8
Sony Acid Pro 7
Sampletank 2 XL
EZDrummer
Guitar Rig 5
ProTools 12.3
All legit software thank you very much.
Yes I have a low post count but only because I don't have a lot of problems with my gear.
Old 11-05-2009, 09:50 AM
Thanks hue,
I am using Windows 7 Ultimate 32 bit.
Did I download the correct PT? PT LE 8.0 upgrade? Remember this is a new drive (1.5 TB) with no previous version of Pro Tools loaded.
Also remember... I am using the Mbox Pro via Firewire - not USB.
Old 11-05-2009, 10:00 AM
kelldammit kelldammit is offline
if memory serves, the 8.0 upgrade (not an update) should be pretty huge (1gb+), and came as a zip file...it has a few subfolders for the instruments, etc. it's a "fresh" installer. if 7.x were on the system, it would prompt to uninstall that first.
it should install fine. have you tried right clicking it and running it as administrator?
kell
Old 11-05-2009, 10:06 AM
Haven't tried the admin/right click option yet. I'm at work now. My PT machine is home. I'll give that a try later. Thanks!
Old 11-05-2009, 10:10 AM
no problem. also, whenever you run pt, make sure you right-click/run as admin.
you can also just turn off User Access Control to get around this (msconfig, last tab, disable UAC). if you're using the machine for web surfing/email, etc in addition to PT, i wouldn't recommend it though.
good luck!
k
Old 11-05-2009, 10:30 AM
hue hue is offline
Shouldn't be an issue. The upgrade is a full installer. You should download the latest version though. 8.01. Your activation code should still work. There has been issues with Internet Explorer 8 causing Protools to not load. I don't know that this affects installation though.
Intel i7 4770
Dell XPS 8700
16 Gig DDR3
UAD-2 Solo
Steinberg UR44
KRK RP5
Sonar Platinum
Cubase 8
Sony Acid Pro 7
Sampletank 2 XL
EZDrummer
Guitar Rig 5
ProTools 12.3
Old 11-30-2009, 03:47 AM
hey hue, i noticed on your sig you're also running samp9...is that on win7 too?
kell
Old 11-30-2009, 07:45 AM
hue hue is offline
Yeah. Sam 9 on Windows 7 Works just fine. Better than ProTools actually. No error messages ever. And, so far no glitches.
I have to say though, it's weird that I see my old info in my signature and I'm sure I edited it to include a quad core cpu and Windows 7. Is this not the case?
Intel i7 4770
Dell XPS 8700
16 Gig DDR3
UAD-2 Solo
Steinberg UR44
KRK RP5
Sonar Platinum
Cubase 8
Sony Acid Pro 7
Sampletank 2 XL
EZDrummer
Guitar Rig 5
ProTools 12.3
Old 12-13-2009, 08:57 AM
mrmusica mrmusica is offline
Hello
I have followed your suggestings about installing Protools 8 on window 7......It was successful up to trying to open P8.
As I am running in admin. mode the system is stuck at DAE Loaded and does not continue to open PT8 and the digi3 has a continuous lit light at HOST 1394.... has anyone experienced this?
thank you for your help
Pro Tools 10.3.2 wont even install! After clean windows 7 install!!! shamanrock Windows 13 12-27-2012 04:39 PM
1 Pro Tools 10 Install for Mac and Windows mrmeister Pro Tools 10 2 10-26-2012 05:00 AM
HOW DO I INSTALL Pro tools 8.0.4 LE ON WINDOWS 7 32 BIT Rski 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-15-2011 08:02 PM
How to install pro tools 8 on windows 764 bit firefox13 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 08-25-2010 10:13 AM
Can't install Pro Tools 8 LE on Windows 7 ashm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 02-28-2010 12:28 PM
