Getting a lot of "Hardware buffer underflowed (-6085)" messages w/new(er) iMac
So here's some quick background. I recently inherited my dad's late 2009 model iMac, which is a little more upgraded than my 2007 version iMac (faster cpu). After some considerable PITA, I managed to port all of my applications, settings, files etc. from my old one to the new one using Migration Assistant.
Unfortunately, as I was setting up my new iMac in my workspace I only just now discovered that it only has one firewire port (FW800). My old 2007 iMac had two -- a FW400 and an FW800. That worked perfectly because the Mbox 3 uses FW400, but my external drives used FW800, so I had 2 ports to plug everything I needed into the computer. After searching around a bit on the forums here, I saw some people (also people using Macbook Pro, which has a similar dilemma) were doing a particular workaround which was to go using this chain: iMac > FW800 cable to external drive > FW800-to-400 cable to Mbox. However, my setup is a little more complicated because I have three external drives. In order, coming out of my iMac, I've got my 1st external drive (G Drive), which is my audio drive, my 2nd external (G Drive), which is where I keep my sample libraries (SD2, Battery 3 etc.), and then my 3rd external (Glyph), which I use for backups, etc. So here’s my chain: iMac > FW800 cable to G Drive 1 > FW800 cable to G Drive 2 > FW800 cable to Glyph > FW400 cable to Mbox3 (the Glyph has a FW400 port also, luckily) So I tried going this route using this configuration, and it does work. But I’m getting a lot of "Hardware buffer underflowed (-6085)" messages, asking me to either reduce the HW buffer size (doesn’t help) or remove stuff from the FW chain. I tried removing the Glyph from the chain just to see what would happen, and it actually made it even worse. I suspect it's because then I had to use a FW800 to 400 cable from my G Drive 2 to the Mbox, which I guess doesn’t play nice with the Mbox. My Glyph doesn’t really need to be in the chain, but it’s the only one of the 3 drives that has a FW400 port so I don’t have to use the FW800-to 400-cable. Any ideas what I can do? Is there such thing as a Firewire hub or something I can plug into the back of the iMac so I can do a similar setup as I had before? Would that even work?
iMac 21.5" (2017) Intel Core i7 3.6GHz, 1TB SSD, 32GB RAM PreSonus Quantum 2 interface Mac OSX 10.15.6 Catalina 1 G-Drive Pro 4 TB 2 G-Drive 6 TB ProTools 2021.3.1 Melodyne 5 Soundtoys Bundle 5.3.2 Omnisphere 2.6.2 Massey L2007 Superior Drummer 2.3.2 Komplete 13 Ultimate |
Re: Getting a lot of "Hardware buffer underflowed (-6085)" messages w/new(er) iMac
After experimenting around, it would appear that I've fixed my dilemma. I basically reversed the chain (sort of).
The Mbox 3 has 2 FW400 ports on it. So I thought I'd try this: iMac > FW800-to-400 cable to Mbox > FW400 cable to Glyph > FW800 to G Drive 2 > FW800 to G Drive 1 After testing this configuration on several sessions (the previous problem sessions from before, and several others) I haven't had any problems at all. The only PITA is now I always have to have the Mbox on if I want to use any of the externals. Yes, most of the time the externals are used for my music stuff so it'll already be on anyway, but there are a few things for which I use them that have nothing to do with my music (backing up the system drive etc.). I suppose that's sort of a minor inconvenience though for the extra cpu boost.
Error "6085" Buffer Underflowed - Pro Tools 10.1.2 | eotwguitarist | Windows | 12 | 08-01-2013 04:45 PM |
Recording to a new External Harddrive, now "audio device buffer underflowed" | MSCHAAF | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-24-2011 06:07 PM |
"Audio device buffer underflowed..." Help rid me of this buffer error | Jim Digby | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 01-07-2011 09:29 PM |
"Audio Device Buffer Underflowed" Constant Error! | Ro Cho | Windows | 8 | 01-02-2011 09:12 AM |
Mbox 2 Pro "audio device underflowed" error 6085 | blu2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 07-29-2009 04:27 PM |
