Pro Tools 9 "Quits Unexpectedly" on start, when loading Plugins!
This error just started tonight.... Can anyone help???
Im running Mac OS X Lion (10.7.3) & I have a 003 Rack with Pro Tools 9.0.6 Installed... I am soo lost, please help if you can.... |
Re: Pro Tools 9 "Quits Unexpectedly" on start, when loading Plugins!
Got the exact same error today, after upgrading to 10.7.3.
Got me thinking, since when I first installed 10.7.3. Pro Tools ran fine, but 10 minutes later it was dodged. During those 10 minutes all I did was install the "messages beta". And gues what... That was it. I Quit messages, rebooted and Pro Tools worked again :) |
Thanks SO MUCH!!!! ;-) lol That was my problem as well, the thing that got me is that I had Messages selected to run at startup, so even when i restarted I was still never getting in... but cool, I have unselected run at startup and now I'm good to go once again... Now if I use Messages (which I probably will), I will just restart to get into Pro Tools again... Once again, Thanks a lot! I really appreciate your response!
Best Regards |
Hey guys, i have the same problem with PT 9.0.6, Lion 10.7, Digi 003R. What "messages" are you talking about? I'm an experience engineer and been using PT since 5, but I wasn't sure which "messages beta" you were referring to. Thanks so much in advance!
Messages Beta is a new Messaging Program built by Apple to replace the Current (at the time of the post) Apple Messaging Program, "iChat"... A link to the program that I am referring to can be found here http://www.apple.com/macosx/mountain...messages-beta/
hope that helps
. "Harmony i7" Hackintosh running Mac OS X Lion (10.7.3) | Pro Tools 9.0.6 | 003 Rack View System Specs Here - http://www.tonymacx86.com/viewtopic.php?f=54&t=52378 |
I hope this will work for me too! I have this problem for a long time, and now You gave me hope to solve the problem. I will check this out, after i come back home:)
Good Luck ;-)
Pro Tools LE 8 "quits unexpectedly" at launch, after reinstall, and database delete | MWPOP | macOS | 10 | 08-19-2013 05:19 PM |
Pro tools quits unexpectedly "solution" | AdamArnold | Pro Tools TDM Systems (Mac) | 5 | 11-19-2010 09:20 PM |
Pro Tools le 6.0 (and 6.0.1) hangs on "setting up Midi"-- then unexpectedly quits | rdatman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-19-2010 09:15 PM |
Pro Tools "quits unexpectedly" | silverstein | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-19-2010 11:24 AM |
Protools instantly "unexpectedly quits" and wont open at all | travisdunsmuir | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-19-2010 11:23 AM |
