  #6261
Old 06-05-2015, 01:49 AM
shredus shredus is offline
Default
Originally Posted by shredus View Post
So this is a mb issue or a compatability problem with the focusrite? Really want to be sure about my firewire choice here
I'm interested in the thunderbolt adapter also.. Would this work with a digi 002r with firewire 400 into the thunderbolt on the x99 motherboard? Thanks!
  #6262
Old 06-05-2015, 03:22 AM
venturajedie venturajedie is offline
Default Intel i7 4790K PRO TOOLS Monster
Hello !
Can anyone tell me if this configuration work with
Protools PCI Card ? not PCIe !
My Protools is Protools HD with One Core card PCI
My confusion its if The PCI Card work with this motherboard and this CPU
Motherboard - Gigabyte GA-Z97x-UD5H
CPU - Intel i7 4790K
Hackintosh Build.
Thanks !
  #6263
Old 06-05-2015, 07:56 AM
Rotundra Rotundra is offline
Default thunderbolt
first
Make sure your MB has a TB header for the PCI card, that means its TB ready.
I can tell you that 2 different FW 400 (non combo) cards did not work with 2 different asus x99-a MB's
What I cannot say is why for sure.
Asus thunderbolt II pci card with an apple TB to FW 800...then an additional 800 to 400 adapter is the only solution here for my Focusrite with a FW 400 interface.
BTW focusrite sent me a FW 800 to 400 adapter no charge.
PT10 with sapphire 56, Ivory 2, into this build: Win7,
Gigaybyte EX-58udr3, Chip: i7/920 bloomfield retail, Ram: Corsair XMS3- 3 channel/6GB Latency 9-9-9-24, Power Supply: Corsair TX650w, Hard disks: (2) WD WD500 32 MB buffer BLACK, Case: Gigabyte GZ-x7 mid atx case with 2 big fans and a Sony dvd burner, Video: HIS Radeon HD 3870 512k GDDR4...Total cost of PC build on 12/2/2009: $1021.00, still kicking after 5 years of daily use.
  #6264
Old 06-05-2015, 10:46 AM
Default
Originally Posted by Rotundra View Post
first
Thanks for the heads up! So this MB is not so good?
https://www.alina.se/ShowCart.aspx?p...GD5=1&S3-WEB=1
It has a thunderbolt port if that is what you mean? Any working alternatives are much appreciated.. I checked the HPz's out.. Nice but pricey here..
  #6265
Old 06-05-2015, 05:37 PM
Default Re: i7 Builds - Specs and Results
The MB must have a TB header (4 pin plug)
I got the TB card and adapter from sweetwater, about 120 for both
The MB is fine but I would not buy another because of the asus service experience
  #6266
Old 06-06-2015, 08:03 AM
Ok, I think I get it now.. Quite a workaround considering the cost and my digi002 might not even like it?!?
This is what you mean (with adapters mentioned) from 002 to TB to motherboard?
https://www.asus.com/Motherboards/ThunderboltEX_II/
  #6267
Old 07-01-2015, 09:58 AM
philip888's Avatar
philip888 philip888 is offline
Wanting to Buy an ASUS Sabertooth X58 Motherboard.
Anyone have one laying around from a previous build?
Please PM me.
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.7
  #6268
Old 07-02-2015, 01:54 AM
maunaloa maunaloa is offline
Default ASRock X99, i7-5960X, and Intel 750 PCIe SSD: HDX2
ASRock X99 OC Formula mobo, i7-5960X CPU, 32GB G.Skill 2133 RAM, Intel 750 PCIe SSD boot drive, ASRock TB2 AIC, Sonnet Tech III-D with 2 HDX cards on TB2, Omni, HD I/O, S3, Artist Transport, SSDs and spinners, Win 8.1 x64, PT HD 12.1, AMD HD 7970 GPU (MSI and Sapphire versions work well), 2 HP ZR30w panels on DP.
Build highlights: Disable trad BIOS before trying to install Win. Intel 750 must have UEFI. PT HD 12.0 and 12.1 with HDX selected as PBE hung at Initializing Audio Engine until I reset the OMNI to factory default. Enable TB in "CPU Setup" in UEFI; TB2 in PCIe slot 3 worked for me. Win 8.1 x64 installed from thumbdrive in 3 min. 30 sec. Don't see a need for a Xeon. Avid just (as of 16 July 2015) listed 8C and 10C Xeons on HP Z840s as the only compatible 2011v3 CPU systems (Avid TS told me that E5-2640v3 and E5-2660v3 Xeons were in the tested systems). HDX cards may not work if installed in PCIe slots on mobos other than in certain HP Z workstations.
I also bought and tried a Gigabyte GC Thunderbolt2 card (dual port) on the ASRock mobo. Worked fine. The mobo TB header pinouts are apparently the same (at least on X99 ASRock and Gigabyte mobos), and ASRock and Gigabyte are both using Intel's TB2 device driver. Don't know about ASUS, Supermicro, EVGA, etc. The current problem in TB2 is finding a PCIe AIC in stock.
ASRock X99 OC Formula mobo, Win 8.1 x64, PT HD 12.1, i7-5960X CPU, 32GB G.Skill 2133 RAM, Intel 750 PCIe SSD boot drive, ASRock TB2 AIC, Sonnet Tech III-D with 2 HDX cards on TB2, Omni, HD I/O, S3, Artist Transport, SSDs and spinners, AMD HD 7990 GPUs, 2 HP ZR30w panels on DP.
  #6269
Old 07-22-2015, 05:59 AM
ISOPROPYL ISOPROPYL is offline
Protools 11
AMD FX-8350 8 Core Black Edition Processor
ASUS M5A99FX-PRO-R2 Motherboard
Kingston HyperX Fury HX318C10FK2/16 16GB (2x8GB) Blue
Sapphire Radeon HD5450 1GB
CONFIRMED WORKING BUILD
DVerb2 test 96 tracks fully populated
Thought I would let you all know
  #6270
Old 07-22-2015, 09:17 AM
Why do you want to run the 002 from a TB port? If you are looking to the future(a wise idea), just add an approved firewire card for the 002($50 tops)
Best Core 2 Series Desktops-Results and Specs sunburst79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2416 02-19-2013 07:49 PM
new to pc builds chazc080488 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 10-18-2011 07:10 PM
any p45 builds fofif5792 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-09-2008 12:47 PM
OSX "builds" Richard Barrie Pro Tools TDM Systems (Mac) 2 10-18-2004 08:37 AM
