Old 10-25-2016, 08:25 AM
rider rider is offline
Default Standard vs. HD Pro Tools for post
hi all,
at my work (which I just left) I have been using HD version.
Now I want to work at home some general editing for post. I do not need surround at this point etc...
As far as I know, timecode ruler is now part of non HD software as well, I can import OMFs and stuff.
My main concern, as I see it now, is video manipulation and I can not find info on whether is possible to cut (I know its only one track possible) that one track.
Sometimes we receive instruction to cut from certain frame to certain frame or to insert some time, where I can just copy few frames to fill needed timeline...
Is this possible in non HD??
Any users that are doing post here on non HD? Anyone care to share experiences and workflow?
Unfortunately I am at the tight budget at the moment and I can not go to HD if it is not absolutely necessary...
Also, I like to know which Blackmagic interface is the least costly, the cheapest one that will allow me to monitor video window on its own screen fullscreen (true fullscreen , not fit the screen option)?
Is it DeckLink Mini Monitor PCIe card? for 145USS?
thank you!
Old 12-08-2016, 11:23 AM
reducedfatoreo reducedfatoreo is offline
Default Re: Standard vs. HD Pro Tools for post
I've been using Standard for my freelance post work and haven't had any major issues I can't work around easily.
I haven't tried cutting the video track in Standard, but if I get any edits I'll just make a new video in QuickTime 7 Pro--it's easy enough to delete or add frames in the same way you're describing. You'll have to add a step because you'll be replacing and reimporting the vid, but at least you have a solution if Standard can't do the basic vid edits you need.
Honestly, the thing I miss the most for my workflow is not having the cmd-/ shortcut available to clear automation in a flat line!
Old 12-08-2016, 06:46 PM
Postman Postman is offline
I'll tell you what I like about HD that is not in standard
Surround bussing and panning (this is a big, really big deal for a majority of post work)
A few "advanced automation modes", the most important to me is PREVIEW
Scrub trim, one of my favorite ways to scrub audio. These days I am very reliant on it as a convenience and time saver.
Back and play, another big time saver while mixing.
http://www.avid.com/pro-tools/compare
Cutting the video track is nice but not one of the things that I use often. Having more than one video track is very nice (sometimes REALLY NICE) but you can get the work done without either of them.
system specs in profile
Old 12-08-2016, 06:55 PM
I've done the same. It becomes a problem only when/if you don't have a timecode window burn in the video already (or the timecode was changed in a way that is not reflected by the window, such as drop/non-drop code changes). You can still do it but the math required is prone to mistakes, I know from experience, and I've seen QTPro-7 indicate there is an extra frame at the beginning of a file when one does not exist in Pro Tools or Media Composer. Without a burn window I don't know that I could be certain about what I am doing.
Just my experience, as always things can go perfectly most of the time.
Old 12-09-2016, 04:36 AM
Originally Posted by Postman View Post
It becomes a problem only when/if you don't have a timecode window burn in the video already.
Yes, absolutely helps to have the TC. Good catch.
HTML code is On
WTB Pro Tools 9 (standard, not HD) Marcel Risberg Buy & Sell 0 08-28-2015 06:56 AM
Pro Tools 11 Support Plan standard with Pro Tools software purchases & upgrades feryano FireWire & USB Audio Interfaces (Mac) 0 11-02-2014 10:21 PM
Pro Tools 11HD advantages over Standard Pro Tools 11 (software wise) hatepop macOS 8 12-10-2013 08:26 AM
If Pro Tools is the audio STANDARD, then why can't I... the barn studios Pro Tools TDM Systems (Mac) 4 12-08-2008 07:35 PM
PLEASE!!!! Need Input on Standard Post Outfit Greek Audio Post - Surround - Video 13 04-08-2007 08:07 PM
