FV-500H Pedal works as expression but not as volume
It won't work at all as volume, despite selecting it in the User Options and calibrating it.
Re: FV-500H Pedal works as expression but not as volume
You must indicate for each rig if the expression pedal is used and also to what it is assigned, for example wah or volume. You can see at the end of the signal chain the settings for your rig.
Make sure it is set accordingly, it was a bit tricky to find for me so maybe it can help your situation. Julien |
Xpand2, want the volume/expression pedal to be something else! | fredmant | Virtual Instruments | 2 | 01-13-2014 02:18 PM |
New User:help with expression pedal volume | gp81 | Eleven Rack | 7 | 09-23-2013 09:00 PM |
Behringer FCB1010 expression pedal (for volume) | patswope | Eleven Rack | 4 | 04-08-2011 01:32 PM |
Expression pedal > Rig Volume > on To Amp out as well? | therealmf | Eleven Rack | 5 | 10-17-2010 11:55 AM |
expression pedal for track volume: live | acroamatom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-06-2008 09:12 PM |
