help with decision
i am going to start playing at church again in a couple of weeks and i am currently using the eleven rack. to play live i will need a midi pedal, so my question is which one should i go with (yes, some options are overkill):
1) midi pedal - behringer with 11prom, or rocktron midi mate or any midi pedal? 2) pod hd500 - can use as a midi pedal or stand alone rig if for some reason the eleven rack fails. 3) digitech gsp1101 with control pedal - same as above except that i can load user IR's and it integrates better with the eleven rack if i want to use both together. those are the three options i have been tossing around for days. help please? |
Re: help with decision
I also have the 11R in a 2U softcase bag also made by Rockbag, hey they make good stuff - and was the only brand the store had in stock . I was never afraid the 11R would fail and if it had, I would just unplug the guitar and go straight into the amp clean. If the amp goes well ... then I guess I'm in trouble .
You're validating my inherent mistrust of strangers. Schecter Hellraiser 7 Diamond - Ibanez RG7620 Eleven Rack w/ ERXP |
I vote for number 1.
I've been using the 11R with the 1010 w/11prom for a year now at my church. I have the 11R in a portable SKB rack case along with a pair of Shure wireless receivers (one for electric and one for acoustic guitar). I recently picked up a SKB soft case for the 1010. Makes it very easy to carry in on a Sunday morning.
Parker Fly Artist, Martin DC16-GTE, 11R |
To be really portable I got the tech21 midi mouse controller and boss fv500 volume/expression pedal. Those + laptop & cables fit in my gator 2U backpack making it very easy to travel.
I have a KMI SoftStep. It's a bit tricky to get your head wrapped around the programming but once you do it is by far the most flexible, powerful and compact pedal I have ever owned. I love mine, it's fully configurable for almost anything I can dream up, and fits in the back of my 2U rack.
I mean if you for example tap DIST and MOD button on 11R chassis would it light up on SoftStep? I know it's rare behaviour of midi switchers to read the current status of FX processor. However it would be great to have such feature. SoftStep seems to be quite advanced, but I'm not sure if 11R can send out its status... Thanks |
I searched high and low and could not find a decent sounding clip of a gsp1101 using custom ir's, so that option is out. i also learned that the gsp1101 only allows 128 tap samples (not big or accurate) and i was told that you need to have about 1024 taps to be accurate.
so i'm looking at the pod hd500 next. this clip is probably the best example of the pod hd500 sounds: http://www.youtube.com/watch?v=z__yOcQOPXU the guy is using an eleven rack now, but he did get some decent tone out of the pod when he did this video. |
Knowing that you came from the GSP, I don't think the POD HD is going to add much and as a controller it works ok but it is nowhere near what you had with the GSP and Control 2. If you still have the GSP and Control 2 you can try to integrate that as a controller to get a good idea of how the POD will react as the contoller for the 11R. In my opinion they are usable but there are too many issues to use live.
If you just want a controller that works with the 11r, the FCB/11prom is the best option by far. |
But vote nonetheless, you never know, it could happen .
Help with pre-amp decision | koncept | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 08-06-2004 12:50 PM |
I need help with this decision.... | primo99 | Tips & Tricks | 11 | 08-01-2004 03:43 PM |
G5 decision | taiazeez | Pro Tools TDM Systems (Mac) | 4 | 09-09-2003 01:09 PM |
Mic decision... | J. Guerrero | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 04-12-2003 08:52 PM |
Please help me with my decision | bradd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 07-19-2002 07:14 PM |
