Old 02-28-2018, 04:41 PM
polyh3dron polyh3dron is offline
Default Batch Renaming only renaming clip, not disk file
In Pro Tools 2018.1.0, I'm doing a substantial amount of batch renaming of clips right now, only to find that the only thing getting renamed is the clips, not the actual audio files. Only way I can get the disk file names to reflect this is by manually renaming each clip afterwards.
Is there some kind of setting I'm not aware of that will allow batch renaming clips to affect the actual audio files as well? And yes, these clips have bolded names in the clip list. No handles on them.
Old 02-28-2018, 05:02 PM
BScout BScout is offline
Default Re: Batch Renaming only renaming clip, not disk file
No. They purposefully made it clips only with no option to make it file name.
Solution is to batch rename "clips" then while still having all the files selected, shift+command+r to rename selected files but just hit enter for every clip. That transfers the clip name to the file name as long as it is a complete file. A tedious step.
Old 07-25-2019, 01:49 PM
weezul weezul is offline
glad I found this thread.
The one time I want to use Batch Rename.... thanks for the tip it got me sorted right out. Another mind-boggling mishap, why not add a check box like in regular rename?!
MacBook Pro: 16GB M1 Pro 8c
Hackintosh: MacOS Catalina, i7 6700k, 32GB RAM, RX580
Pro Tools Studio, RME RayDAT PCIe
http://www.liamgaughan.com
Old 07-28-2019, 10:15 AM
abc1mce2's Avatar
abc1mce2 abc1mce2 is offline
Remember he's talking about whole files here. If you have parts (Separated clips) of the whole file (Clip) in a session and the whole file is no longer in use on a track but still in the clip bin, you must also rename the whole file cause if you don't the whole file will still show the old name in your audio files folder.
What is more relaxing than Music?
Pro Tools Carbon for macOS 12.7.4
My HDX for Windows11.
Gigabyte Z490 Vision D - BIOS F21b
Intel Core I9 10850K Windows11 / macOS 12.7.4 Hackintosh / 32GB of Rams
Avid Carbon/HDX 2024.3 Ultimate - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (1)
Universal Audio Apollo Twin|X - UAD2 Pci-E and Satellite USB Octo v.11.0.1 - SOLO 610 - Twin-finity
Bricasti M7 (2)
Lexicon PCM96
Neumann KH805 - KH310
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
Crash in 10.3.7 whilst renaming a clip LukeHoward Pro Tools HDX & HD Native Systems (Mac) 0 09-02-2013 11:25 PM
-48 error on renaming clip tamtamstudio macOS 0 07-23-2013 02:22 PM
Renaming region and disk file - line 1242 error KRiemann Pro Tools TDM Systems (Win) 0 08-17-2011 01:34 AM
Batch Renaming isn't numbering sequential, why? Premo Pro Tools TDM Systems (Mac) 2 08-19-2009 10:17 PM
Batch Renaming App minister Pro Tools TDM Systems (Mac) 4 08-10-2006 09:14 AM
