Old 06-28-2018, 11:47 AM
Inglesworth Inglesworth is offline
Default Batch renaming SFX files using Finder question
I have libraries I have been collecting for many years now. I have already gone through and batch converted the old .sd2 files to .wav.
But some of my older libraries have illegal characters in the file names (most commonly, "/").
I didn't have any problems importing them until I upgraded to PT 12, but now when I drag from the workspace, I get an offline clip and have to go rename the file and remove the illegal character and then reimport.
I finally had enough and wen to do a batch rename in finder (OS 10.12.2). I searched the SFX drive for filenames with "/"' in them, and asked it to replace all instances with a space.
Apparently, many of the files have the ".wav" in the actual file name, and Finder is asking if I want to Add the extension or not. The issue is that I am getting asked this for each individual file over and over again. It's a lot of files...
In PT, there's the option with tese pop ups to hold option and click on an answer, and it will automatically apply that to each time it has that question in the process. Does anyone know of a way to do this in Finder?
It won't even let me cancel it. I can only Choose "Add" or "Don't Add" and every time I click I just get the same question again. If anyone knows how to just tell it to do what i select for every file in the process that would be super cool.
Old 06-28-2018, 01:48 PM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
Default Re: Batch renaming SFX files using Finder question
Have you tried renamerator?
http://thecargocult.nz/utilities.shtml
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3
MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM
MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24
Old 06-28-2018, 02:45 PM
minister's Avatar
minister minister is offline
Use the built-in Automator Application.
or, better yet:
http://www.publicspace.net/ABetterFi...version10.html
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 07-17-2018, 11:36 AM
admix's Avatar
admix admix is offline
Been using R-Name for years.
It's no longer supported, but still available.
http://www.jacek-dom.net/software/R-Name/
Stephen Rosen
SonicUnion
19 Union Square West
New York, NY 10003
Old 07-17-2018, 03:28 PM
Meads Meads is offline
ForkLift 3 can also do it and I think there´s a free trial.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 07-18-2018, 07:08 AM
+1 for R-Name. It's simple, quick, and free. But, it will stop working once Mojave takes over as all 32-bit apps will loose support. A Better Finder Renamer is a good paid option.
EDIT: Ah, according to the link it IS 64-bit. Hopefully it will continue to work for a long time.
Scott Gatteño
Old 07-18-2018, 12:38 PM
TrentWilliams TrentWilliams is offline
I use 'A Better Finder Rename' - works really well .. although I haven't tried the others.
http://www.publicspace.net/ABetterFinderRename/
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • DockMac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W
HTML code is On
Batch Renaming only renaming clip, not disk file polyh3dron Pro Tools 2018 3 07-28-2019 10:15 AM
Batch Clip Rename not renaming audio files - just clips PT 2018-3 MixerGuy Pro Tools 2018 12 02-09-2019 08:45 AM
Batch Renaming isn't numbering sequential, why? Premo Pro Tools TDM Systems (Mac) 2 08-19-2009 10:17 PM
Batch Renaming App minister Pro Tools TDM Systems (Mac) 4 08-10-2006 09:14 AM
Lost files and renaming files GoneIndie Pro Tools TDM Systems (Mac) 2 01-13-2005 07:08 PM
