Old 11-16-2005, 08:36 PM
Tom Pfaeffle Tom Pfaeffle is offline
Default Waves automation parameters gone
I am running 6.9.1 cs 2 TDM and have lost all waves parameters on some of my sessions. Various sample rates. When clicking on the "auto" button in the plug window- nothing in the list.
Any one else finding this.
Tried deleting prefs, databases and waves prefs-
No luck yet.
Old 11-16-2005, 10:16 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Default Re: Waves automation parameters gone
Same thing here, TDM 6.91cs3, deleted all prefs, removed EQIII, and DynamicsIII per others suggestions.
ALL my third party plugs have this problem, but NOT the Digi plugs!!!!
But my LE system doesnt have this issue.
IMDB
Old 11-17-2005, 12:20 AM
Steve MacMillan Steve MacMillan is offline
I have seen this too. Try turning on automation for a parameter by control-option-command clicking on the knob or fader you wish to automate.
STeve
macmandigital.com
Old 11-17-2005, 09:14 AM
Peter Duemmler Peter Duemmler is offline
I´ve had this, too.
Updating to Mac OS X.4.3 solved that problem.
Peter
http://www.merlinsound.de
Old 11-17-2005, 10:15 AM
Yes, but Im in the middle of a season, and can not risk upgrading the OS to Tiger!!!
IMDB
Old 11-17-2005, 10:16 AM
Tried that, no good!!
IMDB
Old 11-17-2005, 10:21 AM
That's wierd, because it's working for me.
STeve
macmandigital.com
Old 11-17-2005, 11:53 AM
I'm running 6.9.1cs3 on OSX 10.3.9 (Quicktime 6.5x).
If I open a test session, and then open a Waves plug-in, then the automation parameter list is working. But if I open a URS 1970 compressor, and then open a Waves plug-in the list is missing. It seems that the URS compressors are affecting the Waves automation list.
STeve
macmandigital.com
Old 11-17-2005, 02:39 PM
Andre Knecht Andre Knecht is offline
I’m not sure this issue should be laid at the door of URS. I don’t have any of their plugs installed -- not even a demo -- and I recently noticed the issue described in the original post.
As Steve MacMillan pointed out, the keyboard shortcuts work fine (at least here). Ironically, I only noticed the disappearing automation parameters bug because of a previous post raising the issue, which prompted me to go and have a look. I always use the shortcuts.
10.3.9
6.9.1cs2
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
Old 11-17-2005, 02:51 PM
filmixer filmixer is offline
You know, I had this happen to me the other day while mixing ITB. I added a PitchBlender plugin for a "Robot Voice" effect and none of the automation parameters were there. It wasn't a show stopper or anything since I found a preset an just left it as is, so no automation needed. The session was started from a template which I modified by changing plugins here and there, adding automation parameters to the new plugs and everything else worked fine. I've mixed many shows on this system and this has never happened before. The only difference is the recently added Dynamics III plugins, which were being used in the session on a couple of dialog chains. Hmmmm...
G5 Dual 2.0, 10.3.8, 6.9.1cs3, Control24.
Mark Ettel C.A.S.
how do you erase all automation parameters at once? Anibal Pro Tools TDM Systems (Mac) 11 05-04-2018 05:33 PM
No automation parameters displayed on some plugins Marco Migliari Pro Tools TDM Systems (Mac) 2 12-15-2005 01:07 PM
plugin automation parameters are gone RCN Pro Tools TDM Systems (Mac) 4 12-12-2005 12:44 PM
Disappearing automation parameters Roy Pahlman Post - Surround - Video 3 11-22-2005 06:51 AM
Automation Parameters Missing boogiemotel Pro Tools TDM Systems (Mac) 1 11-21-2005 06:19 PM
