how do i recrod left only channel from audio cd ?
jamey aebersold play along cd? how do you record it into Pro Tools? I tried and it does not split..just records everything stereo...using XP and 6.4 thanks
Re: how do i recrod left only channel from audio cd ?
Well, isnt it supposed to record in stereo and then you pan to the side you want to hear in ProTools?
Ill suffer winter alone; ten thousand miles from home... |
Just drag the left of the stereo file into a mono track.
it\'s wierd but i seperate it out and still hear
both tracks playing..that's the problem..should i just delete the track i dont want? or the master audio that was oroginally recorded? and how would i rerecord it onto a new track and put the bass and drums in stereo? possible? thanks for the help
Re: it\'s wierd but i seperate it out and still hear
import the track into Protools(File--->Import Audio to Track)
select the imported track, and make it two mono tracks(File--->Split selected tracks into Mono) mute or delete the right track. ev
ik zei nooit dat! |
Left Channel Audio Regions on Timeline force to Original Stereo | leobaker | Pro Tools 10 | 2 | 11-10-2013 10:41 AM |
Pro Tools Audio Playback only in Left Channel | Sean12345 | General Discussion | 3 | 10-12-2010 06:16 AM |
Left Channel stops passing audio | montezuma | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 04-07-2010 07:13 AM |
Left Channel (not Mono sum) audio only | AnMorrigan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-21-2009 04:45 AM |
left channel audio is playing at a lower volume | nodrog1213 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-02-2004 04:42 PM |
