Old 02-20-2004, 05:17 AM
E-an E-an is offline
Default converting audio to midi
Im looking for a way to convert drums tracks into MIDI triggers. It strikes me that Beat Detective is more than up to the job of analysing drum tracks and creating sync points from the transients, but is there any way of turning these into MIDI notes?
Any other suggestions would be most appreciated (Im just trying to find a solution without setting the kit up with MIDI triggers).
Thanks in advance,
e
Todays posting was brought to you by the letter e
Old 02-20-2004, 02:04 PM
Allan Speers Allan Speers is offline
Default Re: converting audio to midi
e,
There's a PC-only app that does this fairly well:
http://tallstick.com/
I have yet to see such a thing for the current Mac OS.
If you have an older Mac, and can find a copy of the last rev of Studio Vision, you might get by with that. It did audio-to-midi, but wasn't exactly flawless.
Old 02-21-2004, 12:57 PM
Drew Mazurek's Avatar
doesn't DP do this?
www.drewmazurek.com
Old 02-22-2004, 11:26 AM
Tweakhead Tweakhead is offline
There is a hardware solution in the Alesis DM4 and DM5. Roland also make one.
I believe Logic can do this too.
Old 02-22-2004, 02:19 PM
CCash CCash is offline
There's a shareware app for Mac called d-sound pro, search for it with Google.com. It worked on OS 9 for transferring audio from Pro Tools to a ddrum brain (as MIDI sys ex data).
Old 02-22-2004, 06:51 PM
El Goodo El Goodo is offline
DP has a plug called "Trigger" I belive that does this. I've seen it used, but can't speak to the quality. A pal that used to do a lot of drum and bass swore by it.
Old 02-23-2004, 11:37 AM
Rubo Rubo is offline
Try Melodyne 2.1
http://www.celemony.com/
Cheers.
Converting midi to audio smrpg99 Pro Tools 9 3 12-20-2012 07:14 PM
converting midi to audio using..... noaortiz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-26-2011 02:46 PM
Converting Audio To MIDI kCmCg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-07-2003 04:11 AM
Converting MIDI to Audio nukmusic Pro Tools TDM Systems (Mac) 4 10-08-2002 08:54 AM
Converting Midi to Audio DougSt.Louis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-08-2002 12:50 AM
