Old 09-01-2003, 12:43 PM
E-an E-an is offline
Default Mis-routing internally within ProTools
Hi there,
I've been having some bizarre problems with ProTools recently and cant seem to get to the bottom of it. Sometimes when loading up sesions signals are mis-routed internally within the protools mixer itself. Other things have been happening like signals being mis-routed in and out of hardware e.g. 888.
Could this be due to changing interface around and re-configuring the IO setup? If so how can I clear the slate and reset all the preferences. The system specs are below:
G4 1.25Ghz w 1.25Gb Ram - running OS 10.2.6 and PT 6.1
d24 core system w 2 farm cards.
888|24 connected to d24 core (had previously been 1622 but this needs a new cable, hence a different IO setup).
MidiMan MidiSport 2x2 USB
Lacie 120Gb FW Ext HD.
Thanks in advance.
Iain
Todays posting was brought to you by the letter e
Old 09-01-2003, 01:54 PM
Tweakhead Tweakhead is offline
Default Re: Mis-routing internally within ProTools
Usually just opening a session with a different IO setup will not cause these symptoms, unless you have appended an IO setup to an existing set of paths.
If you want to get rid of everything, go to IO setup... on each tab select all path names and hit 'delete'. Then click on 'default' and your default set of paths will be created.
You will LOSE any routing that existed in your session so make a few screenshots before you do it, so that you can recreate any bussing etc.
Old 09-02-2003, 05:25 AM
kurt's Avatar
kurt kurt is offline
Take a very close look at yours interface cables. Look for bend pins. Good Luck
MBP early 2011. Apple MacPro 5.1 12Core ”Westmere”. DeckLink HD Extreme 3D+. OS X10.10.5
PTN|10-11. PTN|HD|10-11-12. 16 x 16 HD I/O - 16 x 16 192 I/O Lots of gear.
http://www.mmvstudios.com
Routing in Protools & 003 asef@me.com macOS 2 12-26-2013 06:59 AM
Routing problems in ProTools luffe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 03-09-2010 01:46 AM
Dynamic routing on protools pushkar Pro Tools TDM Systems (Mac) 1 11-19-2009 02:51 PM
ReDrum Routing in ProTools??? armanikane 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-23-2006 12:54 PM
Logic 7 internally synced with Protools TDM? 24bit dither Pro Tools TDM Systems (Mac) 10 01-31-2005 01:19 AM
