Old 08-05-2003, 11:57 PM
JGriffith JGriffith is offline
Default Routing other audio programs (Peak and Jam) through Digi Hardware
How do i listen to the output of Roxio Jam in OSX with an HD3 system through the digi hardware?
Jim Griffith
Matthews/Griffith Music
Burbank, CA
www.matthewsgriffith.com
www.beatdisciples.com
Old 08-06-2003, 08:14 AM
SMSanchez SMSanchez is offline
Default Re: Routing other audio programs (Peak and Jam) through Digi Hardware
I am having similar problems. We just updated our HD system to OSX and cannot make the 192 the default sound device. When I go to System Preferences>Sound>Output, the only option it gives me is the Built in audio controller -- its like its not even recognizing the 192. PLEASE HELP -- this is very frustrating.
Old 08-06-2003, 09:15 AM
Avid's Avatar
Avid Avid is offline
Administrator
You need to install the Digidesign Core Audio Driver to route the audio from Bias Peak, Roxio Jam and other programs to your Digi hardware. A list of supported applications, download and details here:
http://www.digidesign.com/download/coreaudio
Roxio Toast with Jam 5.2/5.01 (set the Sound Out to Mac OS X Audio HAL)
<font size="2" face="Verdana, Arial">For system sounds, the core audio driver won't work. The easiest way that I've found is to route your mac audio out to a mixer if posssible. Also from the core audio page:
Digidesign Core Audio Driver Q & A
Q: Why can't I hear my Mac system sounds through my Digidesign hardware using the Digidesign Core Audio Driver?
A: The Digidesign Core Audio Driver for Mac OS X does not support playback of system sounds. There is an issue with the OS X Sound Preference Panel that makes it appear the "Digidesign HW" can be selected under "Sound Effects" but this functionality is not supported by the Digidesign Core Audio Driver. Your Mac system sounds will continue to be available through your Mac speaker and regular Mac line out.
Administrator
Old 08-06-2003, 04:47 PM
E-an E-an is offline
We currently have a d24 core system...
are there any plans to make the digi core audio driver compatible with this system? Or will the current drive work, but is untested?
TIA,
Iain
Todays posting was brought to you by the letter e
A quick peek at New HD hardware and Light Peak... Citrin Pro Tools TDM Systems (Mac) 14 09-24-2010 03:43 PM
routing audio out of pro tools into other programs ?? mickblah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-22-2007 10:04 AM
Digi! About hardware exchange programs to PCIe bad jitter Pro Tools TDM Systems (Mac) 0 10-29-2005 11:47 AM
PT vs programs which don't require their hardware sndchck 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-20-2005 01:32 PM
Software that temporarily disables hardware for me while running certain programs? GuitarEasley 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-21-2002 11:56 AM
