Command 8 and Protools Versions
I probably can guess the answer to this but will the Command Eight work only with Version 6.4 of protools or will it run with say 6.1 ?
Thx, Iain
Todays posting was brought to you by the letter e |
Re: Command 8 and Protools Versions
It ships with 6.4 I believe. 6.4 is required.
Rail
Platinum Samples www.platinumsamples.com Engineered Drums for BFD |
You have to have 6.4 or higher
=========== Apple G5 2.0 DP 4 Gig Ram, 2 x 250 HDs HD2, 192 I/O with A/D expansion Digidesign PRE and Midi I/O |
Thanks for the help guys....
I was just browsing through the protools folders on the mac (as you do!!!) and noticed that the control surface personalities are all stored in one specific folder... has anyone tried copying across the command-8 personality to see if an earlier version of protools will pick it up? Just wondering (possibly suicidal but who knows)! Thx, e
Profiles are specific to versions, but if it ships with PT6.4 it means if you purchase one you get the correct software anyway????
Unless you are trying to avoid upgrading your Mac O.S. problem takes care of itself. |
Basically the system Im getting comes with 6.4 i.e. 002 system. However the studio I am also using uses a d24 system on 6.1 (as 6.4 isnt available for the d24 and may never be). Therefore I was just trying to figure out if I could get the command|8 to work on 6.1
It would appear not however... oh well. Thx, Iain
ProTools Utility Plug-In Versions | TimNielsen | Pro Tools TDM Systems (Mac) | 3 | 03-12-2009 04:58 PM |
2 versions of protools installed!! Help! | scar97 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 01-16-2009 09:14 PM |
opening older versions of protools in v/ 6.9.2 | ahead1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 11-09-2005 09:44 AM |
New versions of OSX & Protools.... | RBaker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 03-09-2005 11:34 AM |
2 ProTools versions on same computer? | didger | Pro Tools TDM Systems (Mac) | 2 | 07-04-2003 09:07 AM |
