Old 01-08-2004, 07:06 AM
plevanto plevanto is offline
Default Can´t send MIDI to a plugin
hello!
I just updated to ProTools 6.2.2
When I open Kontakt, B4 or Reaktor as a RTAS-plugin and try to play it, I cannot make the plugin recieve any Midi data. ProTools recieves MIDI okay, but the plugin doesn´t respond. In standalone mode I´m able to play it them my keyboard with no problems.
Does this have something to do with the peripherals-setup?
I hope you can help,
Pessi Levanto
Helsinki, Finland
Old 01-08-2004, 10:54 AM
mersisblue mersisblue is offline
Default Re: Can´t send MIDI to a plugin
check out your midi studio setup it probably got wiped out when you upgraded
Old 01-08-2004, 10:57 AM
Darin Donovan Darin Donovan is offline
You might also check to see whether you are running OS9 in "classic" mode when this happens. I have to run it for my email (don't ask...) and it messes with the MIDI every time...
Monster of Love
Old 01-08-2004, 11:06 AM
Thanks for your replys.
I´m not running classic mode when this happens. I´ve also made sure that classic mode is not launched at startup.
My MIDI setup seems to be okay. As I said, with Standalone versions it works perfectly.
any other suggestions?
Pessi
Old 01-08-2004, 11:22 AM
The only other thing I need to make sure I do is to start my midi device as soon as the Digi start up screen shows on the computer. In other words, I can't be sure my MIDI will work properly if I start up my keyboard before starting protools or after it has already started. I know this sounds kooky, but it works for me. Good luck!
Monster of Love
Old 01-08-2004, 11:45 AM
Have you assigned the MIDI output in the MIDI track to the MIDI plug-in..? Have to ask .
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 01-08-2004, 12:07 PM
Slim Shady Slim Shady is offline
Sounds like you didn't create a MIDI track to go with your plug-in track. Create a MIDI track and assign its output to the plug-in you want to hear, then make sure the MIDI track is in record mode and that the volume is up on your plug-in's track.
ProTools 8.0.4 doesn't send MIDI to Yamaha S90 ES; midi out ports [Emulated] bbirney Pro Tools M-Powered (Win) 8 05-19-2018 06:58 PM
Aux send plugin order johnnybregar Artist Series 1 10-08-2011 03:34 PM
Plugin & Send Control Soundtrack2life ProControl, Control|24, Command|8 1 05-22-2011 06:14 PM
How to send midi into a 192 I/O ungratefuldead Pro Tools TDM Systems (Mac) 9 04-26-2010 06:59 AM
Plugin sounds fine used as insert, but phasey as aux send Che_Guitarra 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 07-15-2008 04:30 AM
