Syncing external drum machine to PT. Only works from 1st bar.
I´m syncing my Jomox Alpha Base to PTs Midi Beat Clock via USB Midi. Works fine when I start playback from the beginning of the session. It wont work from any other bar than the very first though. I can see tempo info being received by the Alpha Base. The start signal is apparently missing though.
Ableton offers a "pattern" mode for syncing external gear. MIDI Clock Type The MIDI Clock Type "Song" is used to transmit the Song Position Pointer information together with the MIDI Clock, which is useful when syncing another DAW to Live. If the synced device is a drum machine or groove box that plays looped patterns, "Pattern" type is recommended instead. Is there a similar option available in PT 12.4? What am I missing here? |
Re: Syncing external drum machine to PT. Only works from 1st bar.
In Synchronization preferences there is an option to generate MTC. Try that.
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
Ah, should have mentioned. Tried that already. Does not work. The Alpha Base does not read MTC.
syncing external drum machine | yorgo | Pro Tools 9 | 2 | 02-25-2014 02:30 PM |
syncing external drum machine | MPB | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-11-2013 11:54 AM |
Syncing Drum Machine to Pro Tools | cletus | MIDI | 2 | 01-04-2006 07:52 AM |
Syncing drum machine to PT? | Animal | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-04-2005 12:05 PM |
questions with syncing up my boss drum machine | johnnymojo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-02-2004 02:47 PM |
