Go Back   Avid Pro Audio Community > Live Sound > VENUE Live Sound Systems
Old 12-02-2017, 06:39 PM
Pilaf Pilaf is offline
Default VENUE Plug-in problem, jerky
Hello!
i have a Venue profile with version 3.1.1.286.
The problem occurs when I use any plug-in, when I operate on the plug-in every 5 seconds the plug-in locks for 2 seconds in which I can not control any parameter, even the meter goes into freeze for 2 seconds, is a cyclic problem. It's just a problem of visualization and operation,the audio signal is fine.
I thought it could be caused by the EcX driver for remote control, but I uninstalled it and the problem remains.
I run the DigiTest and it's all right.
Can you help me?
Thank You
Old 12-03-2017, 09:38 AM
Kristo Kotkas Kristo Kotkas is offline
Default Re: VENUE Plug-in problem, jerky
Just an idea - if there is a certain plugin you see this on, try to disable all the rest of the plugins only and have that one enabled and see, if the sluggishness goes away. If it does, start adding back the plugins in half patches, not all together (remember what ones you enable back) and test each time for the sluggishness to re-appear. This way you can filter out if you have a plugin installed that causes this issue.
Old 12-13-2017, 02:56 PM
vikingthor vikingthor is offline
Originally Posted by Pilaf View Post
Hello!
Can you help me?
Thank You
Is it in every showfile? And if you change the system settings on input channels and how you use groups does this have an effect ?
Old 01-02-2018, 09:57 AM
RyanJ's Avatar
RyanJ RyanJ is offline
Have you tried doing a restore of the console? I would imagine that some plugin install has screwed something up a bit.
Ryan John
Principal Product Manager | Avid Live Sound
[email protected]
Plug-ins on Venue? nickdesigner VENUE Live Sound Systems 19 12-16-2015 12:18 PM
Odd plug-in problem VENUE mbm1987 VENUE Live Sound Systems 3 04-02-2013 10:11 AM
Venue 3 and Plug-In Thumbnail Problem Kenmillerjr VENUE Live Sound Systems 9 08-08-2012 03:08 AM
VENUE stock plug-ins Jason Stygar VENUE Live Sound Systems 5 02-17-2011 08:40 AM
Suggested VENUE plug-ins mariobenipayo VENUE Live Sound Systems 10 08-09-2009 08:55 AM
