Old 12-27-2004, 08:09 PM
iceblueD iceblueD is offline
Default A7N8X PC with a boot up problem!
I have a A7N8X Motherboard with a Athlon XP 2100+. This is the very first problem I have had with this setup. It all began about 3 days ago when I would boot up my computer and it would hang right before Windows XP loaded. It popped up a message "A Disk Read Error has occurred, press Ctrl, alt, delete to restart". It will only go to this error message now. I have bought a new hard drive and I have tried to install it but for some reason, I cant get it to install off of the disk even though the motherboard and bios are recognizing it is there. What can I do?
Daniel J. Webb
Old 12-28-2004, 07:27 AM
powerjoe powerjoe is offline
Default Re: A7N8X PC with a boot up problem!
Have you tried booting and going straight into the Bios by hitting the "delete" key on startup? If not, you may want to try that. If you have done any alternative configuring in the Bios, changing it back to the "default" settings, then hitting F10 and closing may help. Reboot and see if the problem is still there. Also, do you have a boot disk, and can you boot up to that floppy?
Let's see what we can do from there...
Joel DuBay
Ready Acoustics LLC
Bass Traps and Acoustic Panels
www.readyacoustics.com
Old 12-28-2004, 04:06 PM
Well, I dont have anyway to format a floppy for boot up. The computer im on now is a lap top, so I dont have a floppy drive on it. I have tried to run the Western Digital setup diskette, but when it tries to boot from the diskette, it says "Cannot load DOS! Press any key to retry". I have tried resetting the defaults in the BIOS, but it doesnt seem to matter what settings I have.
Daniel J. Webb
Old 12-28-2004, 04:16 PM
Boot into Safe Mode
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 12-28-2004, 04:34 PM
ok, I tried booting into safe mode and after that post screen it just hangs for about 5 seconds saying "Verifying DMI pool data...." and it restarts the computer automatically.
Daniel J. Webb
Old 12-28-2004, 05:18 PM
Booyah Booyah is offline
New Harddrive? replacing the system drive?
Seems like your next step would be to install XP off the bootable CD or restoring from a ghost image (if any).
Verifying DMI pool hang might just need a reset bios to defaults.
Old 12-28-2004, 06:57 PM
bigbadhenchman bigbadhenchman is offline
Check ALL your cables to make sure everything is hooked up correctlty. 99% of most computer problems are cable related.
M-Powered Forum
www.markhensley.tv
Old 12-28-2004, 09:47 PM
JMS40 JMS40 is offline
IceblueD-
Try going into BIOS setup as suggested, and make sure the CDROM is in your boot up sequence, before the hard drive.
Then boot from your XP CD.
Old 12-28-2004, 11:35 PM
bigbubbaj bigbubbaj is offline
Hey booyah, where you from in colorado? Castle Rock here...
5198 Studios
Old 12-28-2004, 11:45 PM
Mac Pro/HD3 boot-up problem Futurist Pro Tools TDM Systems (Mac) 206 05-21-2011 08:07 AM
LE 7.3 boot problem dmf 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 08-14-2009 07:21 AM
g5 boot problem... usd Pro Tools TDM Systems (Mac) 12 02-18-2009 12:34 PM
Boot Problem with OS9 UTS Pro Tools TDM Systems (Mac) 5 01-15-2005 09:55 AM
OSX Boot problem Reckless Erik Pro Tools TDM Systems (Mac) 0 09-24-2003 02:40 AM
