mix core and dsp farm
I searched the duc for this and couldn't really find what I was looking for. What kind of performance can I expect out of a mix core and a dsp farm. I want to use a few verbs, compression and eq. Also auto tune the vocal tracks. How many tracks are possible doing this? Is that too much for that set up? It's on a old 9600 with a G3 500 update so rtas isn't really going to help I don't think.
thanks |
Re: mix core and dsp farm
It gets a bit hard to predict, especially because it depends on which plugins that you'll be using require the mix chips (on your core card) and which don't.
I have a Mix+ (core plus mix farm), and I added a dsp farm to it. In my case it worked out well because many of the dsp hungry plugins I use (ones that take a whole chip like Amp Farm, Pitchblender, etc) happen to work on the DSP farm. In that situation the dsp farm is, for all intents and purposes, 2/3 of a mix farm, making it a great deal. You really need to determine what plugins you want to use and whether or not they require the mix chips. When you start talking about verb plugins, you're almost certainly talking a whole chip per plugin instance. With only 10 chips total, and the possibility of plugins requiring mix chips, you might come up a little short. Tom |
Note that I said "In that situation the dsp farm is, for all intents and purposes". That is, I can run 4 Amp Farms on the dsp farm (one on each chip). The same 4 Amp Farms would use 4 of the 6 chips on a Mix farm.
In that situation, it frees up 2/3 of a mix farm for other use. I wasn't implying that the dsp farm had 2/3 the processing power of the Mix farm, but in the above situation it does, in fact, free up that much. The same situation actually applies to a lot of plugins that will eat a whole chip on either a Mix or dsp farm. Tom |
AG |
AG |
Mix Core, DSP Farm QE, 6.4.1 TdM on 10.3.4 - Farm not shown | Table Syrup Records | Pro Tools TDM Systems (Mac) | 2 | 06-18-2008 08:00 PM |
Mix Farm WITHOUT Mix Core? | SiliconAudioLabs | Pro Tools TDM Systems (Mac) | 3 | 04-21-2005 10:35 PM |
Using mix farm with d24 core | jonathandreamer | Tips & Tricks | 8 | 07-04-2002 02:57 PM |
D24/DSP farm v. Mix core | poppy | Pro Tools TDM Systems (Mac) | 4 | 05-20-2002 12:36 AM |
MIX Core, MIX Farm, DSP Farm & G4 933MHz | Chief Technician | Pro Tools TDM Systems (Mac) | 6 | 04-25-2002 06:59 AM |
