Old 01-10-2016, 06:44 AM
noiseboyuk noiseboyuk is online now
Default EuCon client monitoring service detected a problem and will now exit
Getting this error message when trying to setup on my spare machine (W7 i7 4820k, 24gb RAM, Gigabyte X79-UP4). Have installed EuCon 3.3.2. Works fine after the initial install, but on a restart get the error message:
EuCon client monitoring service detected a problem and will now exit.
Please check your network settings and connections
Error starting up MC_Client
When I try to manually restart MC_Client, PT 12.4 does not work with it. Firmware up to date on the MC Mix.
All working fine on main rig (specs below) running EuControl 3.3.0.
Thanks in advance for any help.
Guy Rowland
www.guyrowland.co.uk
www.sound-on-screen.com - Original audio clips of movies, TV shows and games, licensed as regular production music.
PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i
Macbook Air M2; 24gb RAM
Old 01-17-2016, 06:29 AM
Default Re: EuCon client monitoring service detected a problem and will now exit
With Avid's help, think I found the culprit - it looks like a modern variation of an old 2.x bug:
http://avid.force.com/pkb/articles/e...Null-CORBA-POA
I followed the instructions in the article above (which is exactly what I used to have to do), using batchrun.exe to create a file, starting the three programs with a 2000ms gap between each, in the following order:
EuConStart
EuControl
MC_Client
Looks like MC_Client falls over unless the other two are fully up and running first. Doesn't affect my main machine, just the (very similar) spare - computers, eh?
Guy Rowland
Old 04-27-2016, 09:35 AM
Bassr˙che Bassr˙che is offline
I don't know if you resolve your issue since january, but I hope so. If not, I recently got the exact same trouble. It's start last month and I was very frustrated. I follow the instructions in the article you mentionned but that didn't help at all.
And in the last past hour, I finally solved it.
I uninstalled my firewall (Zone Alarm Pro) and restart the PC. The Windows firewall ask me to authorize Eucontrol and MC_Client. That's what I did and then no more message at the start of the PC.
I re-installed my Zone Alarm Pro firewall and everything still working just fine.
Eucon Client can not access the Bonjour service 8dB.co.uk Artist Series 2 11-28-2015 05:12 AM
Eucon client monitoring service detected a network problem HELP shamanrock Artist Series 1 10-22-2015 09:22 AM
Eucon client can not access the bonjour service - This will NOT install now! shamanrock Artist Series 0 07-24-2014 01:46 AM
Problem with Digidelivery client on one Mac Phill Barrett Aspera DigiDelivery 1 12-08-2009 03:38 PM
mysterious exit problem in PT 5.1.3 c-post Pro Tools TDM Systems (Mac) 1 07-06-2004 06:45 PM
