Old 02-06-2024, 06:07 AM
asdfg asdfg is offline
Default I just upgraded to M2 and now my HDX won't work.
I have had an HDX system for a bunch of years and just upgraded to a Mac Pro M2, the 3rd computer the system has been on. Since the computer came with Sonoma, I am trying to set it up. BUT, the HDX hardware doesn't show up on the engines list. I tried to install the HD driver 2023.12.1 and it fails. I looked in the system extensions folder and there's a DigiDal.kext file from 2011. Evidentally you can only uninstall with the uninstaller of the same vintage as the installer and that one won't run on Sonoma. I have tried using a terminal window to delete, no. I have done the recovery mode/start up utility thing. Avid's help chat is useless. Does anyone have a solution?
Mark
Old 02-06-2024, 06:21 AM
Default Re: I just upgraded to M2 and now my HDX won't work.
Incidentally, I also tried HD driver 2023.3.0 and it also failed during installation.
Mark
Old 02-06-2024, 06:48 AM
K Roche's Avatar
K Roche K Roche is offline
Yes start with this and provide a list of your system details in your post or better yet in your signature line
https://duc.avid.com/showthread.php?t=300050
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
Old 02-06-2024, 07:12 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Which slot are you putting the HDX card?
Does Digitest see card if so check firmware.
Old 02-06-2024, 08:21 AM
Farhoof's Avatar
Farhoof Farhoof is offline
Originally Posted by asdfg View Post
Mark
Have you tried these steps?
https://avidtech.my.salesforce-sites...ation-on-macOS
Old 02-06-2024, 08:52 AM
Originally Posted by Farhoof View Post
yes.
Old 02-07-2024, 07:30 AM
So, I solved it. I put the Mac Pro M2 in target disk mode and used another computer to edit the .kext files out. After that it installed just fine.
Thanks!
Mark
upgraded to 12.8 can't get space to work willl3 AAX Plug-ins 14 08-11-2017 04:00 PM
Upgraded to 10.2, rewind does not work! Vedat ICON & C|24 1 07-10-2012 09:19 PM
Just Upgraded PT. Now Keyboard Won't work. EarHole MIDI 2 08-05-2010 10:45 PM
Upgraded, Now Plugins Won't Work...WHY? a2zproductions 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-19-2003 06:19 PM
I did it, I upgraded to a 002 but now it won't work... Rammelt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-31-2002 12:50 AM
