Old 09-20-2013, 03:53 AM
RoxyRiot RoxyRiot is offline
Default No sound from output of POD XT
I've recently put a Line 6 POD XT into my Pro Tools rig going through my MBox. Everything appeared to be working fine until I went to play back my recording from the POD and although you can see something has recorded, I can't hear it. I've tried it from all outputs in Pro Tools, but nothing seems to work. It's just the POD that is doing this as everything else can be heard.
I've got the POD as an insert in Analog 3 if that gives any clues?
Thanks.
Old 09-20-2013, 04:05 AM
Default Re: No sound from output of POD XT
I forgot to add that I can hear the sound when recording but get nothing when playing back.
Old 09-22-2013, 07:03 PM
tmitchell tmitchell is offline
What do you mean?
It is hard to tell what the issue is without more detailed information, how are the hardware devices physically connected to your computer?
If you have multiple interfaces, check that you have configured them correctly.
No sound output? Soundburst macOS 2 12-01-2011 06:48 AM
No sound in output flyingrabbit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-19-2009 09:12 AM
can't get G4 to see 001 as a sound output hay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-02-2006 01:22 PM
Help with Sound Output RockToTheTop 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-03-2002 11:38 AM
No Sound Output Gremz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-31-2001 10:37 AM
