BUG: Nudge Underlying Audio/Sync Point
Maybe this has been covered before, but when you use ctrl +/- to nudge the underlying audio (while leaving the start and end the same), any sync point in the region stays in its absolute position, and doesn't move with the audio (!).
Defeats the point of using sync points... And, yes, for the record, this is my biggest problem with PT9 |
Re: BUG: Nudge Underlying Audio/Sync Point
I don't think it ever did.
Right. I think sync points might have always behaved this way. But it still doesn't make sense.
Assure you, this feature works just as intended. It just saves you a couple of mouse drags: instead of having to first move the sync point and then drag the region to align the sync point to the corresponding event, you just nudge the underlying audio using this shortcut.
Vovique, I'm not sure I follow. The nudge function works fine, the issue is that if you have an existing sync point, it doesn't move with the audio. That's the problem.
This bug is especially problematic in music editing. |
It is a region sync point. As such it is tied to the region, not to the sample. You want a sample level sync point, which PT does not do at this time.
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
Nudge and sync point | henpage | Pro Tools 10 | 0 | 08-07-2012 10:26 AM |
Sync point doesn't move with ctl-nudge (?!) | alex weber | Post - Surround - Video | 1 | 08-14-2010 03:08 AM |
Crtl-nudge and sync-point | Frank Kruse | Post - Surround - Video | 3 | 04-09-2009 02:16 AM |
Sync point doesn't move with ctl-nudge (?!) | reichman | Post - Surround - Video | 0 | 11-24-2008 12:52 PM |
Snap sync point to sync point? | imi | Tips & Tricks | 3 | 05-25-2003 06:48 AM |
