7.4 still showing problems when relinking
7.4 is still showing the old re-link bug. I open a session that used to be completely online yesterday. I haven´t changed anything. I open it 90 files offline (all avid-media). Relink-window comes up. I chose manual relinking and select only the drive with the files. I chose name & ID. No matches. I chose name. No matches. I close PT do the usual DB-delete hoop-jumping. I repair permissions. I reboot. Launch session. Same files offline. I select one of the files and hit "find candidates" and instantly get a match. I confirm relink. I select all others and hit find links again. No matches found. I repeat the whole procedure. Same problem So now I have to hand-click find candidates and confirm for 80 files?! (Ironically it´s actually faster to hand relink 80 files using "find candidates" than to wait for an automatic relink wich takes about 40 minutes till finally NOTHING is found) OK. So I hand relink 80 files. I Save. Close session. Re-open to verify. Now 40 files offline?!?!?!?!? Some of the files that were offline before. I give up. What do I do? Why the flip does "find candidates" always find stuff while "find links" doesn´t? What ever "find cadidates" does differently could you please use that code and replace the "find links"-routine with it? Frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Relinking Problems "targets of an incomplete render...' | DAEerror | macOS | 2 | 06-17-2019 08:39 PM |
Having problems relinking audio files | riffmachine | Pro Tools M-Powered (Win) | 1 | 01-20-2009 03:19 PM |
Relinking Audio Problems | 1511 | Pro Tools TDM Systems (Mac) | 1 | 08-09-2006 08:41 PM |
PT and relinking problems | Loudigi | Pro Tools TDM Systems (Mac) | 5 | 09-27-2005 08:21 AM |
Problems showing Grid Value Pop-up | letco85 | Digidesign Hardware & Software | 2 | 11-14-2000 01:36 PM |
