Exporting wav files
Can someone explain how I can export tracks as wav files? The manual isn't quite getting me there. I'm using PT le 7.0.
Thanks Tim |
Re: Eporting wav files
Tim1,
Highlight the source file (or region/s) in the drop down region list. Click on top bar for the menu to appear. Select "export regions as files" Set output attributes, and destination directory...export good luck, andrew
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
Where is the regions list hiding. Do I need to save the project before I can export?
The list is "hiding" at the right side of your edit screen. Find the ">>"" looking little arrow at the bottom right and click. a
Thanks Andrew, I found it. Now I'm trying to export to my cd drive but keep getting this wierd pop-up message.
Assertion in "\code\aztec_Staley\AlturaPorts\NewFileLibs\Sy s\ line 232 |
Search the knowledge base for that error message.
I would just save it to a temp folder and use your CD burning application to write the disc from there. best of luck, a
I think you're right. Thanks for the help.
Tim |
exporting OMF files | Peter Groom | Post - Surround - Video | 3 | 07-05-2013 03:54 AM |
exporting files | andrewr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-09-2008 02:21 PM |
Exporting files | Raifer | Tips & Tricks | 6 | 11-14-2005 01:08 PM |
Exporting Files | Yankee Hotel Foxtrot | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-28-2004 01:49 PM |
Exporting files from Mac to PC | surchur | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-15-2001 08:52 AM |
