Need Auth code for downloaded 6.4 upgrade Where???
I downloaded the upgrade to 6.4 and istalled it on my PC. Now when I start PT it wants an Auth Code from the inside cover of the "Upgrading to ProTools 6.4, etc..." Booklet, but I don't have one. Where am I supposed to get this code?
I tried entering my 6.1 code, but it says it's invalid. Of COURSE, I do this right after Digidesign closes for the weekend! Any help is appreciated Thanks in Advance H |
Re: Need Auth code for downloaded 6.4 upgrade Where???
The same PTLE 6.1 serial number that you used to download should also authorize PTLE 6.4.
Make sure you are entering it the same way it appears in your 6.1 upgrade booklet or getting started guide: The first 4 letters are all caps: DIGI All other letters are lower case All “0” characters are zeros, not letters If the same serial number you used to download does not authorize, then it is probably not a problem with the serial number. Something else is more than likely going on with your authorization. Go through all of the troubleshooting steps in the thread at the top of the forum: http://duc.digidesign.com/showflat.php?&Number=802377 ...particularly updating your PACE drivers and deleting preferences.
Administrator Avid Pro Audio Community |
Thanks so much for taking time to reply! I walked away and took a break. When I returned a while later I realized that I copied the Auth Code from 6.1 and was deleting a letter for some stupid reason. I feel like King Dunce! Thanks again! Howard |
Auth Code lost in upgrade? | TrevorFWiggins | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-30-2010 11:27 PM |
Upgrade to Pro Tools 8 (with upgrade dvd) asking for Auth code? (HELP) | Mista808 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-12-2010 01:40 PM |
HELP Downloaded Pro Tools Upgrade, Code No Where to Be Found | chillax69 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-04-2008 08:17 AM |
Help!!!! 6.2.2 to 6.4 upgrade!!! auth code!! | Pettenatti | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-30-2005 01:19 AM |
LE 6.4 upgrade auth code? validate? | bonehead | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-01-2005 09:37 PM |
